NEED HELP
Sungho1997
16
IS IT COMPATIBLE WITH EACH OTHER AND PLAY GAMES WITHOUT LAG???
CPU: Intel Core i5-2500K 3.3Ghz 1155pin Boxed CPU $212
Motherboard: ASUS P8P67-V3 DDR3 Intel 1155pin Motherboard $155
RAM: G.Skill Ripjaws-X F3-12800CL9D-4GBXL 4G Kit(2Gx2) DDR3 1600 $44
Hard Drive: Seagate 3.5" Barracuda 1TB ST31000524AS SATA3 7200RPM 32MB HDD $55
Graphics: Gigabyte 1GB 6850 PCI-E VGA Car $172
Case: Thermaltake Dokker Tower Case without PSU $62
PSU: Gigabyte ODIN 585Watt Power Supply $63
DVD: Samsung External Slim Size DVD RW $29 on 23/07 ONLY,Limited 1 per customer $35
Total: $798
Your CPU is a bit overpowered for your GPU. Check-out what AMD has, they're usually cheaper and offer comparable performance. The GPU is always more important than the CPU, but they need to both be good. For instance, you can get a AMD Phenom II x4 965 for a lot less, and it's still quite good. Consider upgrading your GPU with the money saved, but the current GPU is already ok, if you would rather pocket the money.
