I have P4 3.2C
asus p4c800e dlx
kingston hyperx dual ch. kit 2x512mb pc-4000
At the lowest possible cpu voltage (I think its 1.5500V) and DDR voltage 2.75 I can hit 232mhz fsb x16=3712mhz completely stable. However, if i go up just 1 more mhz I get a black screen after I type in my password for windows xp then my computer restarts. I tried upping the cpu voltage to 1.5625 and got the same results, went up 1 more same thing, and again after that with no luck.
CPU temp is 32C idle, 36C under heavy load(which has seemed to be the same through the OC and at stock rates) case temp is about 36-38C.
I read that when issues arise to up the cpu voltage, but how much do you up it? I've seen posts on the net as high as 1.90V. I just haven't had any luck with the small incraments in the bios and places have said to do it 1 incriment at a time so I started getting confused.
Can I take a slightly bigger step?
What's the limit for a safe voltage on a northwood core?
Thanks for putting up with my newbiness
asus p4c800e dlx
