G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
A non-internet enabled friend of mine has this printer. He tells me
that when the paper feeds into the printer it's grabbed by the bottom
right hand corner, pulled askew and crumpled. I looked into the
opening at the top of the printer and see that the next part of the
mechanism down below is not aligned with the opening but is angled
backward increasingly toward the right hand side.
This may be a design feature, perhaps something that comes forward in
operation to cause a single sheet to be fed into the rollers.
Alternatively, it may be damaged. If this secondary section is meant
to be aligned with the top opening, this may account for the small
rectangular hole in the transverse section below it, on the right,
which may have housed a peg or something similar to hold things in
alignment.
I can't give the printer a trial run at present for other hardware
related reasons but some advice on the situation would be appreciated.
Regards,
Mike Halmarack
Drop the EGG to email me.
alignment.
Regards,
Mike Halmarack
