Question Need to connect to a tv 15 meters away
Aug 31, 2019
Hello,. I will be moving to a new house and i want to connect my pc to the living room tv. The problem is that the tv is about 13 to 15 meters away. I was thinking of buying a long hdmi cables like 20 meters. The other way i was thinking of doing this is by buying a cheap hdmi to Ethernet adapter from ebay and run it that way. My main concern is the latency. The tv is 4k but i will be playing in 1080p. I want you to Suggest me the best way i can run this without having latency problems. If you have any other suggestions, i would love to hear it
Specifically look for an active cable. This will contain signal boosters inline to get the necessary reach. These also only carry a signal in one specific direction, so you have to look at the cable to see which end is the source end , and which is the destination end. If plugged in backwards, you will not get a signal
