[SOLVED] New at building gaming PC (Asking for help)
Mar 19, 2020
Recently I thought about getting a pre-built PC but I been told about how it's better to build one and that it's cheaper. Soo I decided to start thinking about building one. However I don't know what parts to get for it. I mean literally everything. I have seen a couple of YouTube tutorials on how to build one but not how to find the correct parts. I'm completely brain dead about this and completely new. If anyone knows a link for a step by step video or guide on how to find the correct parts that would be really useful. Or if anyone has any suggestions for what parts I can use? I would love to hear any build ideas from anyone. My current budget is $1,500 USD. I have been told I can get something good out of that instead of buying something overpriced that won't be as good as what I paid.
That is true. Are you good with your hands? Follow directions? Then it is an easy process.
What monitor do you have, resolution is important.
Do you have a Micro Center near you?
This is a solid gaming rig for 1080p and would leave room for a other things, maybe a nice monitor. Or you can upgrade the parts a bit too. Just an idea of what you can get.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ Best Buy)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory ($81.99 @ Corsair)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive ($149.99 @ Adorama)...
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB WINDFORCE OC Video Card ($399.99 @ Amazon)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case ($79.99 @ Best Buy)
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($109.99 @ B&H)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($139.99 @ Other World Computing)
Total: $1251.92
Generated by PCPartPicker 2020-03-19 14:49 EDT-0400
Total: $1251.92
Yes, i'm good with hands and following step by step.
1. I currently have a monitor but I plan on passing this down to a younger sibling of my mine, So I plan on buying a new one. So to keep it short, I don't have a monitor, but I'll buy a monitor. Not sure what type though.
2. I don't have one nearby me, The nearest one would be 2-3 hours away. Which would be in Tustin for me.
3. Thanks for showing me this layout. The budget is smaller than I thought it would be. Besides taxes, and overall payment.
I also found this, What do you think of this?
https://pcpartpicker.com/guide/nvttt6/enthusiast-intel-gamingstreaming-build
