Hello, my first time posting so I'm sorry if my formatting is bad.
BUILD:
I7-13700k (I flashed the BIOS for it to work)
32GB Trident Z5 - DDR5 6000 (Also tried Corsair Vengeance 5000)
Gigabyte 4080 (Also tried GTX 1080 ti)
MPG Z690 Carbon Wifi (Also tried MPG Z690 EDGE DDR5)
1TB 990 M.2
2TB Crucial M.2
XH1000 Corsair PSU
Let me know if there's anything else I'm missing.
Context: After installing Windows and my drivers I started playing Warzone with some friends, after thirty minutes or so the computer crashed/hung/froze, I don’t know the correct term but the monitors had the last images on them still and I had to hold the power button to shut the machine down. Note: For most of my troubleshooting it would take multiple restarts for the computer to reboot to Windows properly. It would often power up, half the mobo lights come on (sometimes check DRAM LED) and I would need to hold the power to restart.
I initially swapped out my new GPU with the old one, but I would still crash after 30 minutes or so of light to heavy loads. From gaming, to work video meetings, to watching youtube videos.
I then reinstalled windows, and redownloaded Discord/COD… Twice. Still, it crashed.
I then swapped out the RAM with the ram in parenthesis above, but still ran into the same issue, though I was able to play for close to an hour.
I then swapped mobos (I started with the edge and bought the carbon to replace it) to no avail. Still crashed after 30 minutes or so.
At this point, I’ll probably try replacing the PSU and then the CPU but I figured I’d check here for any advice. Has anyone run into a similar issue and found success? Any thoughts are appreciated![Smile :) :)](/data/assets/smilies/smile.gif)
BUILD:
1TB 990 M.2
2TB Crucial M.2
XH1000 Corsair PSU
