Question New Build Help $2500, Help Nytmare
Nytmare
134
9
18,685
Hello all !
It time to upgrade my existing desktop. The prior build is about 6 years old and showing its age.
So here is what I picked out for the upgrade. The computer would be used for gaming and some work -_-
My gaming is mainly at 1080. I am not sure my Asus 34” curved monitor would support 4k.
Please look at the build and give me your suggestions. Thank you in advance.
-Not sure if the Corsair H100i V2 CPU cooler can be used on the new build, so I did pick out a new cooler.
-I have had good luck with Asus, Corsair, Gskill, but open to your input.
My budget is around $2500 USA.
Preferred site: Newegg.com
Overclocking: never done it, but may do it with this build
CPU:
Intel Core i5-13600K - Core i5 13th Gen Raptor Lake 14-Core (6P+8E) 3.5 GHz LGA 1700 125W Intel UHD Graphics 770 Desktop Processor - BX8071513600K
CPU COOLER:
CORSAIR CW-9060060-WW iCUE H150i RGB ELITE Liquid CPU Cooler
MOBO:
ASUS ROG Strix Z790-F Gaming WiFi 6E LGA 1700(Intel® 13th&12th Gen) ATX gaming motherboard(16 + 1 power stages,DDR5,four M.2 slots, PCIe® 5.0,WiFi 6E,USB 3.2 Gen 2x2 Type-C® with PD 3.0 up to 30W)
GPU:
ASUS TUF Gaming NVIDIA GeForce RTX 3080 V2 OC Edition Graphics Card (PCIe 4.0, 10GB GDDR6X, LHR, HDMI 2.1, DisplayPort 1.4a, Dual Ball Fan Bearings, Military-grade Certification, GPU Tweak II)
MEMORY:
CORSAIR Vengeance RGB 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model CMH32GX5M2D6000C36
-OR-
G.Skill Trident Z5 RGB Series (Intel XMP) 32GB (2 x 16GB) 288-Pin SDRAM DDR5 6000 CL36-36-36-96 1.35V Dual Channel Desktop Memory F5-6000J3636F16GA2-TZ5RK (Matte Black)
SOLID STATE DRIVE:
SK hynix Platinum P41 2TB PCIe NVMe Gen4 M.2 2280 Internal SSD l Up to 7,000MB/S l Compact M.2 SSD Form Factor SK hynix SSD - Internal Solid State Drive with 176-Layer NAND Flash
-OR-
SAMSUNG 970 EVO PLUS M.2 2280 2TB PCIe Gen 3.0 x4, NVMe 1.3 V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7S2T0B/AM
HARD DRIVE:
? not sure
Equipment that I have and planning on keeping in the new build:
Full Lian Li Tower Case
Corsair HX Series, HX1000, 1000 Watt, Fully Modular Power Supply, 80+ Platinum Certified,
Corsair Hydro Series H100i V2 Extreme Performance Water / Liquid CPU Cooler. 240mm (CW-9060025-WW)
Sound Blaster AE-5 Plus Sound Card
ASUS Republic of Gamers Swift PG348Q 34" 21:9 Curved Ultra-Wide G-Sync IPS Monitor
• In-Plane Switching (IPS) Technology
• HDMI + DisplayPort Inputs
• 3440 x 1440 Resolution
• 1000:1 Static Contrast Ratio
Old Equipment that is available:
SAMSUNG 960 EVO M.2 250GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E250BW
WD 1 TB Hard Drive
Why Me or whoever....
With the holidays things got too busy to order the PC upgrade parts.
With the release of new hardware options for 2023.......would any of the above upgrade suggestions change ?
Again looking at a budget of around $2,500 USD. Prefer Newegg, but okay with Amazon.
Would like to keep unless told otherwise:
  1. ASUS Republic of Gamers Swift PG348Q 34" 21:9 Curved Ultra-Wide G-Sync IPS Monitor
  2. • In-Plane Switching (IPS) Technology
  3. Lian Li Full Tower Case
  4. Sound Blaster AE-5 Plus Sound Card
  5. Corsair HX Series, HX1000, 1000 Watt, Fully Modular Power Supply, 80+ Platinum Certified,
Again, thanks in advance for your input !
Reactions: Why_Me
The gpu listed down below is way overkill for your resolution but until Nvidia releases the 4060 / 4060 Ti I'm going to post this. btw this gpu was just released today so the reviews on it should start showing up on sites such as this one within the next few days and yes I'm going to catch hell for recommending it for your resolution but you have the budget for it and one day you might size up to 1440P and that's where this gpu is going to tear it up as in RTX 3090 / 3090 Ti FPS. You just may end up with the fastest 1080P gaming rig known to mankind. lol
https://www.techpowerup.com/302975/...usd-799-with-performance-matching-rtx-3090-ti
NVIDIA GeForce RTX 4070 Ti 12GB Graphics Card $800+
All these cpu's down below were just released today. The non F version of the cpu's means it comes with integrated graphics.
https://www.techpowerup.com/302937/...ced-13th-gen-core-desktop-processors-with-65w
https://www.newegg.com/intel-core-i5-13400f-core-i5-13th-gen/p/N82E16819118431
Intel Core i5-13400F $209.99
https://www.newegg.com/intel-core-i5-13400-core-i5-13th-gen/p/N82E16819118430
Intel Core i5-13400 $239.99
https://www.newegg.com/intel-core-i7-13700f-core-i7-13th-gen/p/N82E16819118428
Intel Core i7-13700F $379.99
https://www.newegg.com/intel-core-i7-13700-core-i7-13th-gen/p/N82E16819118427
Intel Core i7-13700 $409.99
The B760 / H770 boards just started showing up today and they will continue to show up on sites such as Newegg every few days or so.
If you plan on going with a single M.2 NVMe SSD then look at a B760 board. I'll use this one as an example.
https://www.newegg.com/p/N82E16813144585
MSI MAG B760 TOMAHAWK WIFI $219.99
If you plan on running dual M.2 NVMe SSD's then look at a H770 board. This one should show up on Newegg any day now. Expect it to run $250.
Reactions: Ar558 and Lafong
Kudos to the great info people have provided. It is much appreciated!
1. Why should I go with the H770 or B760 as opposed to the Z790 mobo ?
2. If I am getting a gaming GPU, why would it be important to have the integrated graphics on the CPU, like the Intel Core i7-13700F $379.99 that you listed.
3. RE time frame....I would like to order pretty soon, but I am not on hard deadline, thus can wait a week or two, if there is something on the horizon worth waiting for.
4. SSD/HD: currently have 250 mb SSD for Windows, then 1 TB traditional HD for "data" (games, programs, file folders). With upgrade was thinking of one SSD for Windows then second drive for data......SSD or traditional HD. Recommendations appreciated (think drive #1 windows, drive #2 data).
5. Any comments on DDR5 vs getting DDR4 memory ?
Q1; primarily to save money....rather than spend on features you may not need.
Q2; integrated graphics can be useful if your video card dies or is misbehaving in some way.
Q3; all you can do is pound review sites for info on the most recent CPU and board releases. They will be filtering out over the next few weeks. You decide when you can't wait any longer.
Q4; I'd certainly try to avoid any spinning hard drive. You could use one largish SSD for everything or split it up into maybe 500 GB SSD for Windows and apps and maybe 2 TB SSD for everything else. I use the 2 drive method, but it's not a big deal. You can get 2 TB NVMe SSD for under 150. Boot drive of 500 gb might be 50 to 80 bucks. Samsung/Western Digital/Crucial. No need to get latest/greatest NVMe if your board does not support it. You need to know how many M2 ports your board has and whether they support NVMe or SATA or either.
Q5; Compare price differences for DDR4 versus DDR5. The gap varies week to week but is generally narrowing. Maybe DDR5 5600? You might not be able to tell the difference if you didn't know which you had, but you may want to stay on DDR 4 if in a budget crunch. Personally, I'd go with DDR 5 if budget allows. You might be able to get DDR 5 cheaper direct from manufacturer (Crucial/Corsair) rather than from vendor like Newegg/Amazon. Prices jump around significantly.
Reactions: Why_Me
OKAY,
I would like to pull the trigger and place the order in the next day. 😳
Very special thanks to.....Why_Me and LaFong for the prior help.
Please take a look at the final build choices prior to me ordering.
Thank you very much !
CPU
Intel Core i7-13700KF - Core i7 13th Gen Raptor Lake 16-Core (8P+8E) P-core Base Frequency: 3.4 GHz E-core Base Frequency: 2.5 GHz LGA 1700 125W None Desktop Processor - BX8071513700KF - Newegg.com
This was my prior choice:
Intel Core i7-13700K - Core i7 13th Gen Raptor Lake 16-Core (8P+8E) P-core Base Frequency: 3.4 GHz E-core Base Frequency: 2.5 GHz LGA 1700 125W Intel UHD Graphics 770 Desktop Processor - BX8071513700K - Newegg.com
What am I getting with the newer KF over K except slightly lower $?
CPU COOLER
CORSAIR - iCUE H100i ELITE LCD Display Liquid CPU Cooler 120mm Fans + 240mm Radiator Liquid Cooling System + Custom IPS LCD Screen - Newegg.com
My case setup would work better with a dual fan radiator set up vs. a tri fan set up
This looks to be compatible with the LGA 1700 socket
MOBO
ASUS Prime Z790-A WiFi 6E LGA 1700 (Intel 13th&12th Gen) ATX Motherboard (16+1 DrMOS, PCIe 5.0, DDR5, 4x M.2 slots, Intel 2.5 Gb LAN, USB 3.2 Gen 2 Front Panel Type-C, Thunderbolt 4 (USB4), DP) - Newegg.com
Still have my "eye" on.....
ASUS ROG Strix Z790-E Gaming WiFi 6E LGA 1700 (Intel 12th&13th Gen) ATX Gaming Motherboard (PCIe 5.0, DDR5, 18+1 Power Stages, 2.5Gb LAN, Bluetooth 5.2, Thunderbolt 4, Support up to 5xM.2) - Newegg.com
This MOBO is on back order on Newegg. I think I can get it from another site. Ordering from one site at once is nice, but not required.
MEMORY
G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3636F16GX2-TZ5RS - Newegg.com
(I did check the MOBO compatible memory chart)
-OR-
CORSAIR Vengeance RGB 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model CMH32GX5M2B6000C40W - Newegg.com
Any thoughts on the two choices?
GPU
ASUS ROG Strix NVIDIA GeForce RTX 4070 Ti OC Edition Gaming Graphics Card (PCIe 4.0, 12GB GDDR6X, HDMI 2.1a, DisplayPort 1.4a) - Newegg.com
PRIMARY STORAGE
Western Digital WD_BLACK SN770 M.2 2280 2TB PCIe Gen4 16GT/s, up to 4 Lanes Internal Solid State Drive (SSD) WDS200T3X0E - Newegg.com
DATA STORAGE
WD Blue WD80EAZZ 8TB 5640 RPM 128MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive - Newegg.com
OS
Microsoft Windows 11 Home (USB) - Newegg.com
Subtotal (8 Items):$2,828.91
Cheers,
Happy 2023 !
Reactions: Why_Me
OKAY,
CPU
CPU COOLER
MOBO
MEMORY
-OR-
GPU
PRIMARY STORAGE
DATA STORAGE
OS
Cheers,
Happy 2023 !
The ROG Strix is geared for OC hence the beefier VRM's.
Reactions: helper800
Offhand....
Does budget prevent avoiding spinning hard drives entirely?
WD 770 is dramless and PCIe 4.0. Some will be skeptical about dramless, although it seems to be a good performer. Alternatives would be WD SN850 or various Samsungs.
"What am I getting with the newer KF over K except slightly lower $?"
You are getting nothing other than lower cost. You are giving up a fallback video capability. You've decided the fallback video is not worth the 28 dollars difference.
Do you have a specific reason to need a board with 4 or 5 M.2 ports...priced at 310 and 500 respectively?
Reactions: Why_Me
Offhand....
Hello,
1. I had rough budget of around $2,500 USD. I am currently a bit over. If it is recommended, I could add some $ for SSD on both primary and secondary drive. Currently have a 250 mb SSD for Windows and 1 TB spinning HD for data.
500 mb would probably be plenty for Windows and 2-4 TB plenty for data in my current situation.
-Any specific SSD choices here appreciated.
2. Which CPU has video capability? (The K I think 🤔)
3. See #1. I think 2 M.2 ports would be plenty for my needs.
I have in the past usually gone middle ground for the mobo with respect to cost $.
I do not for my need to go for the $750+ Ferrari boards, but I am blessed enough with my good job, I do not want to cheap it either.
4. Again, the budget was rough. If you see an area in the build where I can get a good benefit by spending a bit more, I am very open to do it (for example changing 4070ti to 4080 ?) Additionally, if I am way overspending on a component, let me know please. 😳
I was trying to incorporate some of the feedback given to me in this thread. ✌
Hello,,
1. I had rough budget of around $2,500 USD. I am currently a bit over. If it Is recommended, could add $ for SSD on both primary and secondary drive. Currently have a 250 mb SSD for Windows and 1 TB transitional HD for data.
500 mb would probably plenty for Windows and 2-4 TB plenty for data.
Any CPU with an "F" in model name does NOT have integrated video.
So...13700 and 13700K do; 13700F or 13700KF do NOT.
Storage: you are the world's foremost authority on how much capacity you need. You say 2 to 4 TB, but have chosen an 8 TB spinner.
Not sure why. Backups? Future growth rate of data?
You can get 4 TB SSD like Crucial MX 500 for 270 at new egg. Standard 2.5 inch SATA.
Or Crucial 4 TB M.2 for 250 to 275.
If you in fact need 8 TB, then maybe you are forced by budget to a spinning drive. You would know the answer to that.
You say you need only 2 M.2 ports, but your possible boards support 4 or 5.
Not sure why you have your eye on those specific boards. What is the BEST reason?
Do you have a particular attraction to Asus boards? Or reason to avoid MSI or Gigabyte?
How about this:
13600K, not 13700
Air cooling, not liquid. Noctua, Be Quiet, or ?
4 TB Crucial MX 500; no spinning drives at all
Boot drive: M.2 between 40 and 80 dollars; 250 gb or 500 gb; which is not highly critical if from Samsung or WD or Crucial.
Motherboard: your choice; 250 dollars or less; MSI or Gigabyte; with 2, possibly 3 M.2 ports; maybe B760 or B760M. Not sure why you've chosen Z motherboard.
What does all of that do to your budget?
What does that do to your storage ideas? Are you OK with 4 TB not 8 TB?
Nothing overtly "wrong" with any of your choices, but I'm wondering about your thought process regarding the allocation of the 2500 to each component in the PC?
Reactions: Why_Me
Hello,
  1. With a budget that big you should be able to allocate enough for at least a 1TB SSD. (personally I would get 2 SSD's, a 500GB for Windows, and 1TB for Apps and Games).
  2. Intel CPUs all have Graphics EXCEPT those with an F (So both F and KF don't but K and nothing (i.e 13600) do)
  3. Two M.2 ports should be fine, if you really need more storage it is likely to be bulk which you can put on SATA as it won't need to be superfast.
  4. Personally all the 40 series cards are very bad value. But if you must the 4070ti is probably the least worst option. Personally I would see if you can get a 6800XT at a decent price could be a lot better value.
Again thank you for the help.
To clarify, I am thinking 500 mb would be plenty for OS primary drive.
2-4 TB would be plenty for second data drive
Currently, my old rig has 250 mb SSD for OS and 1 TB spinner for data (only used at this point 1/3 of the 1 tb)
So a recommendation for the 500 mb and a 2 maybe 4 tb second drive would be awesome
second drive, I am fine with SSD or spinner
Would like to order things tonight.....feeling that I am overthinking the upgrade too much at this point 🙁
Also, if I went 4070ti to 6800 XT, I would need to change my MOBO chipset choice to ?
Any ATX board will work with either of those gpu's.
Samsung 970 Evo Plus
https://pcpartpicker.com/search/?q=Samsung+970+Evo+Plus
Well,
Hopefully, I did not screw the pooch, and order something wrong 😳
I did read and research all the good advice given on this thread.
I also did a PCPartPicker check off all the parts to check compatibility. I even checked the MOBO's qualified list of memory and picked one from the list.
Much thanks to Why-Me, Lafong, Ar558 for your advice and help. Wishes for you all to have a great 2023!
1. Added suggested SSD x 2 and no spinner HD.
2. Went with a Z790 board, I know with the Z790 I probably not going to use full potential, but I think that on this build going to try a bit OC to expand my PC building skills . Additionally, this MOBO was $ on par with alot of the B770 and H770 Mobo's.
3. Intel Core i9-12900K is overkill and hot, but Friday sale at Newegg for $220 off, so what the heck. I was getting liquid cooling anyway.
4. 4070Ti GPU.
$2,929.50
CORSAIR - iCUE H100i ELITE LCD Display Liquid CPU Cooler 120mm Fans + 240mm Radiator Liquid Cooling System + Custom IPS ...
Sold and Shipped by Millennials Boy
ASUS Prime Z790-A WiFi 6E LGA 1700 (Intel 13th&12th Gen) ATX Motherboard (16+1 DrMOS, PCIe 5.0, DDR5, 4x M.2 slots, ...
  • CPU Socket Type: LGA 1700
  • Option: PRIME Z790-A WIFI
Sold and Shipped by Newegg
SAMSUNG 980 PRO M.2 2280 500GB PCI-Express Gen 4.0 x4, NVMe 1.3c Samsung V-NAND Internal Solid State Drive (SSD) ...
  • Form Factor: M.2 2280
  • Capacity: 500GB
  • Memory Components: Samsung V-NAND
  • Option: Without Heatsink
SAMSUNG 980 PRO M.2 2280 2TB PCIe Gen 4.0 x4, NVMe 1.3c Samsung V-NAND Internal Solid State Drive (SSD) MZ-V8P2T0B/AM
  • Capacity: 2TB
Sold and Shipped by BioStar
ASUS ROG Strix NVIDIA GeForce RTX 4070 Ti OC Edition Gaming Graphics Card (PCIe 4.0, 12GB GDDR6X, HDMI 2.1a, DisplayPort ...
  • Memory Size: 12GB
  • Cooler: Triple Fans
G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model ...
  • Capacity: 32GB (2 x 16GB)
  • Type: 288-Pin DDR5 SDRAM
  • Speed: DDR5 6000 (PC5 48000)
  • CAS Latency: 36
  • Color: Silver
  • LED Color: RGB
  • Fan Included: No
Intel Core i9-12900K - Core i9 12th Gen Alder Lake 16-Core (8P+8E) 3.2 GHz LGA 1700 125W Intel UHD Graphics 770 Desktop ...
MOVE TO WISH LIST
BUY AGAIN
  • Operating Systems: Windows 11
  • Bit Version: 64-bit
  • Version: Home
Not only is the 12900K geared for multi threaded applications, it gets beat like a rented mule by the cheaper 13 gen i5, lest we forget that 12 gen cpu's natively supports DDR5 4800mhz RAM while the 13 gen natively supports DDR5 5600mhz RAM.
Okay, I was to able to cancel the bulk of the order before being shipped.
Would changing to the i7-13700K be a good move for around the same price?
Reactions: Why_Me
This allows you to add a 2.5" SATA III SSD in the future if and when you need more storage. This build gives you a super fast rig without breaking the bank.
https://www.newegg.com/black-lian-li-lancool-atx-mid-tower/p/2AM-000Z-000A8
LIAN LI LANCOOL 216RX ARGB Computer Case $109.99
https://www.newegg.com/p/N82E16813145417
GIGABYTE Z790 AORUS ELITE AX $259.99
https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-10#kf
https://www.newegg.com/intel-core-i5-13600kf-core-i5-13th-gen/p/N82E16819118417
Intel Core i5-13600KF $308.69
if you want integrated graphics
https://www.newegg.com/intel-core-i5-13600k-core-i5-13th-gen/p/N82E16819118416
Intel Core i5-13600K $319.96
or ...
https://www.newegg.com/g-skill-32gb-288-pin-ddr5-sdram/p/N82E16820374379
G.SKILL Trident Z5 RGB Series DDR5 6000 32GB (2x16GB) CL32 $189.99 (black)
or ...
https://www.newegg.com/g-skill-32gb-288-pin-ddr5-sdram/p/N82E16820374380
G.SKILL Trident Z5 RGB Series DDR5 6000 32GB (2x16GB) CL32 $189.99 (silver)
O/S SSD
https://www.amazon.com/dp/B07M7Q21N7
SAMSUNG 970 EVO Plus 500GB M.2 NVMe SSD $69.99
Storage SSD
https://www.amazon.com/dp/B07MFZXR1B
SAMSUNG 970 EVO Plus 2TB M.2 NVMe SSD $186.45
https://pcpartpicker.com/search/?q=RTX+4070+Ti
RTX 4070 Ti 12GB $800+
I'm going to show you why I don't recommend an unlocked 12 / 13 gen i7 / i9 cpu for a gaming build. These cpu's are pushed to the limit out of the box. Now facture in all the e-cores the i7 and especially the i9 has and they run hot. If someone was to overclock one of those cpu's they better count on having a $300+ board and a 420 AIO and even then the gains are minimal at best.
https://www.intel.com/content/www/u...-30m-cache-up-to-5-20-ghz/specifications.html
Processor Base Power: 65W
Maximum Turbo Power: 219W
https://www.intel.com/content/www/u...-30m-cache-up-to-5-40-ghz/specifications.html
Processor Base Power: 125W
Maximum Turbo Power: 253W
i7 12700 / 12700F vs the unlocked i7 gaming benchmarks.
I'm going to show you why I don't recommend an unlocked 12 / 13 gen i7 / i9 cpu for a gaming build. These cpu's are pushed to the limit out of the box. Now figure in all the e-cores the i7 and especially the i9 has and they run hot. If someone was to overclock one of those cpu's they better count on having a $300+ board and a 420 AIO and even then the gains are minimal at best.
i7 12700 / 12700F gaming benchmarks.
All modern CPU's aren't really worth overclocking in practical terms as you will never be able to overclock all cores to the inbuilt Boost frequency. You lose out in some scenario either way. Plus you need stupid cooling.
@Nytmare Apologies on the 12900K, the gap isn't as bad overall as Why_Me's 1080p graph but it does appear the 13700K is faster in every scenario and the discount isn't enough to make the price to performance worth it.
It depends on whether you are gaming only on whether you want a 13600K or 13700K. If you don't do much threaded workloads in Windows the 13600k is probably the best bet.
I would recommend not getting the F (13600KF or 13600F), for 2 reasons. Firstly it's great to have graphics built in for troubleshooting. This forum is filled with people with issues they can't solve with there GPU's so unless you have loads of spare GPU's
I would keep the capability, secondly if you do any video transcoding QuickSync is really good (which comes with the inbuilt Graphics) and speeds up transcoding massively.
