New build with old parts
karen2010
19
Ive been having rebooting problems with my computer. I have only had it since around September last year (Someone I knew built it for a fee) He told me all the parts are new, but Ive been shown the HDD today and it's from May 2008. Is this normal to use an old one even if it's new and unused?
OK, first off your Power On Hours are 1536 which equates to 64 days. Depending on how long you leave it powered up, that isn't out of line with what you'd expect. That's a little over 3 hours a day by my rough calculation. Now if it had been over 5000 hours, then we could definitely say that it was used prior to being in your computer. Looking at the rest of the SMART data, SMART is saying as far as the HDD's firmware is concerned, your hard drive is in good health. Take that with a grain of salt though, I've seen drives that I knew had problems and SMART reported it as good.
I also had a peek at the Crystal Disk Mark scores you posted again and I'm ashamed to say this, but I didn't notice the first time I looked at it. Your...
Hi
Did you see the update to my last message? I'm having to look on Amazon because Newegg don't deliver to Hong Kong :0(
I've chosen a different PSU because I couldn't see the one from Newegg. Will it be OK?
You might be right about waiting for the graphcs card, the only thing I was worried about though is, the one I have is not compatible with all the extension packs I have for The Sims 3 . Will it be OK for the time being then with this in mind?
Is this the connector which I will also need? Will I need this with the Amazon PSU Ive posted to you above?
Silverstone Tek Sleeved 1x PCI-E 8-Pin (6+2) 550mm Cable (PP06B-PCIE55)
thanks
Kaz.
Can I just ask...
What is the difference between this fan model...
Corsair CO-9050004-WW Air Series AF120 Performance Edition 120mm Twin Pack High Airflow Case Fan by CORSAIR
In Stock
AND this model...
Corsair Air Series SP120 High Performance Edition Twin Pack Fan (CO-9050008-WW) by Corsair
Only 5 left in stock.
The price difference between the 2 is quite a lot. I am limited to the different sellers because a lot of them don't ship here unfortunately, so the more I can save the better for me :0)
AN UPDATE : I have installed the 2 Corsair quiet addition fans, the difference in the sound and temp is amazing. So all seems good at the moment, I am still going to replace the cheap parts with better ones though. There is virtually no heat at the top of the case any more when I play my sims game, slightly warm is all I would say, and that was only after playing for quite some time I'm still waiting for my anti static vac to arrive :0( but I did manage to carefully remove some of the dust around the heat sink fan whilst the case was open. I'm not sure how to get into the front of the case to clean the front fan, that might be a problem when I attempt to use the vacuum when it eventually arrives, because there is a lot of dust in that area.
Kaz.
