Hey there, ok so I just got a new CPU, Video card and zalman cooler off newegg.com.
(links to items)
<A HREF="http://www.newegg.com/Product/Product.asp?Item=N82E16819116171" target="_new">http://www.newegg.com/Product/Product.asp?Item=N82E16819116171</A>
<A HREF="http://www.newegg.com/Product/Product.asp?Item=N82E16814130203" target="_new">http://www.newegg.com/Product/Product.asp?Item=N82E16814130203</A>
<A HREF="http://www.newegg.com/Product/Product.asp?Item=N82E16835118113" target="_new">http://www.newegg.com/Product/Product.asp?Item=N82E16835118113</A>
I have an ABIT IS7 motherboard that I got roughly 8 months ago at fry's (before the invention of PCI express, kinda bugs me) but for specification purposes here is the same board at newegg <A HREF="http://www.newegg.com/Product/Product.asp?Item=N82E16813127155" target="_new">http://www.newegg.com/Product/Product.asp?Item=N82E16813127155</A>
On to the problem!
Ok the whole deal seems fairly random, basically my computer will just decide to not launch any more applications at some point. If they are open when this 'crash' occurs it doesn't matter; it will keep running them just fine. However if I attempt to launch 'any' new ones (even the task manager 😡 ) it will give me the hourglass for about 5 seconds and then turn back into a cursor where I wait infinitly for an application that will never launch.
Theres 2 clues I do have though. 1 is when I go in for the restart praying this is a one time freaky thing and it will never happen again, task manager pops up and attempts to quit all the applications it failed to launch earlier.
The second thing (and also why I post on the CPU boards) is that this -never- happened with my old slow original P4 with 2 ghz. I quickly noticed the issues stated above after installing my new CPU so I thought a reformat would solve the issue. The strange thing is that it seemed to for a while but It suddenly started doing it again. Temperature wise it's doing fine I think, it's around 44c as I type this.
please use your mighty CPU knowledge to help me!
thanks!
<P ID="edit"><FONT SIZE=-1><EM>Edited by andycorm on 09/08/05 05:10 PM.</EM></FONT></P>
(links to items)
On to the problem!
thanks!
یί∫υєг ρђœŋίχ
