New fans came in today...need help...
pinnacle2009
107
So my 3 Coolermaster fans came in today. I am trying to install them. However, I CANNOT get the screws into those holes! There are no threads in the holes, but as far as I can tell from other observation, this is normal. I am not sure if these screws are just way too big or what. They gotta be the normal size though, all 3 came with the same size screws =/
Any advice to get these in? Didn't ever think that installing fans would be a problem! lol
LOL I just had an idea. Went and tried it, screws slid right it NO PROBLEM :bounce:
I had some lube/grease, put a little bit in the hole and on the screw. It screwed right in as if there had been threads there the entire time lol
