Hello Guys,
My power supply(Cooler Master V1000 Gold PSU) has died after 5 years. And I am looking for new one.
Following is my part list :-
GPU: It's quite old. Planning to replace it in coming months. Mostly by Nvidia Geforce RTX 3060 Ti (maybe Gigabyte RTX 3060 Ti Gaming OC Pro). Nothing finalized here but RTX 3060 Ti looks quite solid and within the budget. So, this will add up 200W to 250W. The Gigabyte one seems to be overclocked and in one of the reviews I've seen, it consumes around 260 W. So, considering the same to be on safer side.
Overclocking : As of now, no overclocking is done. But, may be, I may do in future for CPU. So, want to keep some headroom for that.
I have done a manual calculation as well as checked online with multiple psu calculators (outervision, newgg, pcpartpicker, bequiet, seasonic, coolermaster, ...).
Of all, outervision and newegg looks to be good.
* Following are Outervision Values :-
Following are manual calculations with some reasoning behind the same :-
Considering 680W is required at full load, I think 1000W should be sufficient.
Please let me know your thoughts on this.
Also, please provide suggestions for PSUs. 😉
- MSI X99A Gaming 7 Mobo
- Intel Core i7-5960X CPU
- G.Skill Ripjaws 4 F4-2400C15Q-32GRR DDR4-2400MHz 4x8GB RAM
- PNY Quadro 2000 GPU
- Samsung 850 Pro-Series 2.5" SATA III 256GB SSD
- WD 1TB SATA WD1003FZEX 7200 RPM 3.5" HDD
- Lite-On iHAS124-15 EU ODD,
- TP-Link Archer TX3000E(WLAN+Bluetooth) PCIE Adapter
- Corsair H110 280mm Liquid CPU Cooler
- NZXT Phantom 630 Case
- Non - Overclocked : https://outervision.com/b/BA21pC
- CPU OverClocked @4GHz, 1.3V : https://outervision.com/b/AhA61C
Component | Power Requirement(W) |
CPU | w/o OC : 140, w/ OC : 170 [OC value from Tom's Hardware Review] |
RAM | 12 (3 x 4W per 8GB) [General estimation] |
HDD | 10 (5V x 0.68A + 12V x 0.55A) [From product technical specification] |
SSD | 7.5 (5V x 1.5A) [From product technical specification] |
Optical Drive | 37.5 (5V x 1.5A + 12V x 2.5A) [From product technical specification] |
GPU | 260 |
Motherboard | 70 [General estimation] |
Cooler | 13.5 (3.9W {for Pump} + 12V * 0.4A * 2 {for fans} ) [From product technical specification] |
Fans | 8 [General estimation: using fans came with Case - 1 x 200mm, 1 x 140mm] |
Case | 40 (10W {Inbuilt Card reader} + 30W {Inbuilt Fan controller device} ) [values from outervision, newegg] |
Peripherals | 42 ( 2.5 {USB2.x} + 4.5 {USB3.x} ) * 6) [USB Standard] |
Wifi | 10 [PCIE Standard] |
Total | w/o OC : 650.5, w/ OC : 680.5 |
