Question new ram power on no display/usb power
Jun 20, 2024
4
So I wanted to upgrade my ram to 32 gb so I brought
TEAMGROUP Elite DDR3 32GB Kit (4x8GB) 1600MHz (PC3-12800) CL11 Unbuffered Non-ECC 1.5V UDIMM 240 Pin PC Computer Desktop Memory Module Ram Upgrade - TED316G1600C112U01
off amazon with them saying The TEAMGROUP Elite DDR3 RAM is compatible with Intel Z97 chipset motherboards like the Z97-K
so is could just be no compatibility but cant find out on online or is could be another problem
computer runs and works find with old ram
I have tried 1 new ram at a time in every slot didn't work
tried with old ram in with new ram didn't work
tried 2 new ram at time and all 4 new ram didn't work
I tried resetting the CMOS didn't work
I tried reset bio disn't work
new
tried to lower the frequency manually to 1333 and tried 1 stick , 2 , and all 4 still no display or usb power
also tried frequency manually to 1600 same happened
https://ibb.co/Fm3xgZm
SPECS
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product Z97-K
BaseBoard Version Rev X.0x
Processor Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
SMBIOS Version 2.8
RAM- Kingston part-9905403-558.aoolf serial-2d277038 (2x8gb)
graphics-nvidia geforce gtx 1660 ti
I have tried 1 ram at a time in every slot didn't work
Specs
SMBIOS Version 2.8
you have gone from 16 gb and frequency 1333 to 32 and 1600 the most likely thing is that the motherboard cannot support them, try to lower the frequency manually to 1333 so that all 4 will work
try your old kingston to 1-3 slots and new teamgroup 2 of 4 stick to 2-4 slots , let it to auto and if working will working with low from kingston at1333
cant put kingston in slot 1 because of the cpu fan kingston has been in 3 and 4 form when i got pc 8+ years ago
tried putting new teamgroup to 1-3 slots and old kingston 2 of 4 stick to 2-4 slots didn't work
tried just new teamgroup 1-3 and 2-4 didnt work
tried old kingston in 2 - 4 and worked
