Hi,
I just built my first PC using the following components:
Ryzen 5900x
Crucial 32GB Ballistix DDR4 3600
Asus Rog CROSSHAIR VIII Hero Motherboard
Phanteks Eclipse P600S Case
Corsair RMx Series 850W PSU
GeForce GTX 1070
WD_Black SN850 2TB Gen4 PCIe
There are a couple of issues that I am facing:
a) The case has USB c port on the front panel and to activate it, I need to connect it to the USB 3.2 Gen 2 port on the motherboard. As soon as i connect it to the motherboard and switch on, I get the error: "USB device over current status detected" and the computer shuts off. No error shows up if I disconnect the cable from the motherboard and restart - the computer works perfectly fine (except ofcourse the front panel USB c). I am trying to understand if this is a Phanteks case issue or a motherboard issue? Both items are within return period but I am not sure what should I return. Please advise.
b) There is a USB C port at the back (the motherboard panel at the back) but that port gives me much slower than anticipated speeds. With my Samsung T5, I usually get 500 MB/s on my other system but on this one, I am only getting under 50 MB/Sec. Is there any BIOS setting that I need to modify to get the right speeds?
Thanks!
Ryzen 5900x
GeForce GTX 1070
Thanks!
