ishak
4
Hello,
need to resolve my problem.
No audio sound after upgrade my graphic card (old graphic GT 850 to GTX 550- gigabyte)
ishak
4
I've already update my driver but still no sound......anyway when i replaced the graphic card. i saw a cable which need to unplug & i believe it was a connection for the audio.But this new graphic card was build in sound card.So i'm a bit confused about it.What shall i do next? FYI, my old graphic card was damage before,so i better not to used it anymore
ishak
4
Thanks Se7en123,
But the new graphic card dont have any slot or plug to plug it in.What i was told thats this new graphic card have its own sound card(built in).That why im a bit confused about it...
ishak
4
Thanks Engima,
Yeahhh..you're right...MY GTX550 doesn't have any sound jack to plug it in.
The I/O cable from speaker already plug it in....
Don't know what to do now?
Engima
711
Check to make sure you have some type of audio software installed; Windows should automatically have something like that. After that, go into Control Panel > Sound > Manage audio devices. It may be different for you if you have a different OS than windows 7.
