Question No display after a shut down HELP!
Nov 21, 2020
I recently bought a GIGABYTE AORUS GeForce RTX 2070 Super. I made sure to test all the parts before I assembled the PC. I tested it maybe 4 times and everything worked. I assembled the PC and again everything worked I activated windows and downloaded the most recent version for my graphics card. After that I shut it down and the next day it says no display. All the lights were on and the fans were going. I decided to reinstall the ram but nothing happened. I then reinstalled the gpu. Once I did that their was no display and the LEDs didn't light up. I have a 650 watt psu, but I don't think it is underpowered. The cable management is clean so there isn't any kinks. Also when it was working only 1 out of the 3 hdmi ports worked. Idk what to do, someone help.
SSD silicon brand 1 tb
Ram x2 16 GB rip jaws V series
Hard-drive Seagate barracuda 2tb
Case corsair crystal iCUE 465x
Cpu AMD Ryzen 7
Motherboard MSI B550 Tomahawk
The cpu fan is the box one that comes with the Amd Ryzen 9 cpu
And I have 2 other fans from cooler master.
Update your post to include full system hardware specs and OS information.
Question: by "downloaded the most recent version for my graphics card" you mean the GPU drivers - correct?
What was the source of those drivers: did you download the drivers via the manufacturer's website or some third party site?
Did you manually do the download, reinstall, and configuration yourself or did you use some driver installation utility?
Will the computer boot via Safe Mode and the display work then?
Is your motherboard configured for integrated GPU (iGPU)? If so, then try that directly.
If that fails then try iGPU via Safe Mode.
Yes I got the most recent version for my GPU driver from the original site no third party i followed the steps for installation so I guess a installation utility and I didnt play around with the settings and unfortunately I don't have a iGPU
Idk how to boot in safe mode, how do I do that?
Edit: I tried hitting F8 to get into safe mode but don't you need to be able to see to go into safe mode?
