[SOLVED] No displayport connection after nvidia installation
saintequila
431
5
18,795
Hi,
I have the Asus VP249QR gaming monitor. and somehow the DP connection isnt working. Removed old drivers using DDU while on DP (working) but when it gets back to normal bootup and Nvidia drivers are automatically detected, DP wont be detected anymore. I tried the power cycling test for 5-10mins unplugged and still same results. Im running out of options. Please help. Im currently on HDMI, the moment I switch to DP i wont have anymore signal. All plugs are well inserted with no loose ends.
Ok so update, i tried a different display port from my work office PC, and it suddenly worked?! Could it be an incompatibility with the cable im using?
