Question No signal on my aoc monitor
Jul 16, 2020
So I have 2 monitors. 1 monitor turns on perfectly fine, but the other has no signal. It was working fine earlier today so I don't know what's up
The one that has no signal is the AOC G2460PF
I have tried unplugging the display port and plugging back in but it didn't fix it.
The only weird thing is when I try to change the input settings on my monitor. I set it to display port but I look back and it automatically goes to HDMI, DVI or DP which all don't work for some reason, which is weird since I have a display port cable attached to it.
Does anybody know how to fix this?
I just switched the display port cables on my working monitor and my 'not-working' monitor. The same monitor doesn't turn on but the same one does. The issue is not the cable.
Latest posts
