Question No signal on my monitor ?
Nov 27, 2024
5
Components I had the problem with
-Z790 Asrock/Z690 Asrock Phantom itx (with biosflash for the newest update)
-NZXT 750w/Corsair SF750
-MSI 1070/Gigabyte 4070
-2 Corsair 32GB
-I5-13600kf
I tried both GPUs on multiple ports with 3 cable, and I know the hdmi works for sure.
I tried all ram slots ins every configuration possible.
Red indicator lights go on while booting but quickly off again( I think that is how it is supposed to be).
All fans and lights are on and visually there is no problem. I think I can even go into windows.
The signal goes lost along the way I guess and I would really need help identifying which one.
If you need any more clarifications please let me know
Make and model monitor?
What connectivity?
How was "I know the hdmi works for sure" determined?
On the host system: any error codes, warnings, or informational events in Reliability History/Monitor or Event Viewer?
"Red indicator lights" - which lights? Check the motherboard's User Guide/Manual to determine what the lights are for and what the color and the meaning ("quickly off again") may mean.
What connectivity?
My monitor: HP X34 Gaming Monitor.
I tried the HDMI cable with a laptop and the x34 monitor. To be sure I tried out 2 DP cables too.
Shortly means 5seconds the Dram and about 10 seconds the boot and vga one. But the manual says if it goes off it should be fine.
I had once the problem with getting a black screen when booting into windows.
Before this, I could get a signal on the old ATX Mobo on the 2nd Pcie slot with hdmi and only the 1070. So It might be an x16 issue.
2 GPU's? ( MSI 1070/Gigabyte 4070).
This motherboard?
https://download.asrock.com/Manual/Z690 Phantom Gaming 4.pdf
Do verify that I found the applicable manual.
Start by reading and reviewing the entire User Manual - doublecheck connections and configurations as you go.
Be sure to read Section 2.8 and 2.9 starting on physically numbered Page 25.
Note the "Star" comments at the top of Page 26.
Wondering about that "Crossfire Bridge".....
2 GPUs means I tested the system with both of them. I don't install both of them via crossfire bridge. And on 25 it says like I said. If the indicator lights go off it should be fine.
This motherboard?
Could it be my CPU? I've tested different Ram slots cables and GPUs. At this point it seems very much like my old psu(nzxt) might have destroyed my cpu
Only one GPU installed then - correct?
How old is tha nzxt PSU?
History of heavy use for gaming, video editing, or even bit-mining?
Are you able to swap in a known working PSU of at least 750 watts or better for testing?
One GPU at a time.
PSU was NZXT c750 I believe between 2021 and 2022.
I have now the corsair cf 750.
I don't think I've done too heavy gaming. Bo video editing or mining.
Shortly before it stopped working I believe I accidentally put off the power distributors switch. It happened twice and then at some point I had no signal.
I heard that nzxt psus are really not good. So I am guessing it is the Psu that caused this, since I've tried most things to get a signal, of which none worked. I think my case is pretty rare but I've tried almost everything and I can't get it to work.
