Hi, my good people,
I just attempted to build a new rig, but nothing happens when i try to boot.
No fans, LEDs or anything is turning on, just completely dead. I have ofc triple checked the PSU switch, tried different outlets etc., but still nothing.
I suspected i had connected the pwr pin wrong, but this was also connected correctly. I also tried manually booting with a screwdriver touching the 2 pins.
Also tried disconnecting graphics card, 1 ram stick, and all power cables except the 24-pin and the 8-pin to the cpu. Still no signs of life.
After trying all this i also noticed an ongoing and even ticking sound coming from the mobo while the the PSU is switched on. I tried with a different PSU and got all the same results.
In my head, this seems like I have a defective motherboard. As if the power is going into the mobo, but not being distributed anywhere from there.
Or could i be missing something? Would be typical of me to forget something really obvious, but in this case i can't really see it.
Here's my setup:
Mobo: ASUS ROG Strix X570-F GAMING
CPU: AMD Ryzen 7 5800X
RAM: G.Skill Trident Z Neo DDR4 3600Mhz 32GB
HDD: WD Black SN850 1TB M.2 SSD
CPU cooler: NZXT Kraken X63 CPU Kjøler
PSU: Corsair RM850x, 850W PSU
GPU: MSI GeForce RTX 3090 GAMING X TRIO
Case: Corsair Crystal 570X RGB Midi Tower
Thanks a lot in advance for any advice!
Here's my setup:
