Not enough sata power connectors
book0006
8
I'm looking to add three or four more drives to my system. However, I only have two sata power connectors left. There's spare molex connectors on the current module cables being used (modular power supply) as well as on the modules not in use. I've seen molex to sata adapters, but I have a couple questions..
First, is there any harm in using a molex to sata adapter?
If not, does it matter if I use the sata connectors and molex connectors on the same module? This guys says no. http://answers.yahoo.com/question/index?qid=20091024145250AAd2hA6
Is he right?
Also just noticed there's no orange wire (3.3v) going to the molex..
Thanks
sturm
Splendid
What the guy was saying no to was plugging in both the SATA Power connection and the Molex power into a SATA drive at the same time. Early drives had both power connections. New drives I believe only have the SATA Power connection.
I have used the adapters with no problems.
Yes you can use both molex and SATA Power connections on one power cable at the same time. I do this myself.
