Hello,
I apologize because you probably see this questions come up a lot. But I can't find any support online for my particular situation.
I have my house wired for Gigabit networking, but the fastest speeds I've seen are 8MB/s. I've only seen that speed once (today), and every other time around 3MB/s. I move large files around so even if I can get the speeds to 30MB/s, would be great.
This is my set up:
Sony Vaio PC --> TRENDnet 8-port Gigabit Switch --> WNDRMAC netgear Gigabit Router --> WD TV Live Hub
Sony Vaio:
- Does have a Gigabit NIC
- TRENDnet 8-Port Unmanaged Gigabit GREENnet Standard Switch (8 x 10/100/1000Mbps Auto-Negotiation, Auto-MDIX Gigabit Ethernet Ports) TEG-S80G
- IEEE 802.11 a/b/g/n 2.4 GHz and 5.0 GHz
- Five (5) 10/100/1000 (1 WAN and 4 LAN) Gigabit Ethernet ports
WD TV Live Hub
- Gigabit Ethernet, USB 2.0, HDMI, Composite A/V, Component video, Optical audio
All ethernet cables used in my house are Cat5e.
The light on my TRENDnet switch is green, not amber, for my Vaio connection.
The light on my TRENDnet switch is green, not amber, for my Router connection.
I cannot seem to find out how to see my connection speed between my router and my WD TV Live Hub.
I also experience the same issue with my NAS... which is a Synology DS211j. That too is connected directly to my router.
Thanks!!!
This is my set up:
Sony Vaio:
WD TV Live Hub
Thanks!!!
