Question Not sure if liquid cooling would fit in build
The NH-D15S is designed for one fan and has clearance for ram up to 66mm tall. Tests show minimal 2c. difference by adding a 120mm fan in front. Not much worth the effort.
It seems that my ram is shorter than that, and it seems - like you said- 2 fans won't make a big difference. I'll get this one and see how it goes.
Thanks!
personally i think the d15 is over hyped the NH-U12A is just as good in most cases and the thermalright is not far behind at less than half the price of the NH-U12A let alone the D15 and over kill on a 5800x3d !!
I kind of gave up on trying to fix the problem so I left the details regarding the issue itself, since I'm just trying to get liquid cooling.
Anyways, the case is Antec P101 Silent.
Cpu cooling - pure rock slim
The currents specs are -
RX 7800 XT
Ryzen 7 5800X3D
Gigabyte B450M DS3H
2 SSDs
2 sticks of 16gb ram
ANTEC PSU 650W Neo Eco Modular 80+
I do keep it under the desk like that, I don't really have anywhere else to put it so there isn't much place for air, thats why i wanted liquid cooling.
There's place in front for a 240 radiator instead of top two fans but a good air cooler would do fine job. There's a new Arctic freezer 36 on the market and if you hurry up it has very low promotional price.
https://www.arctic.de/en/Freezer-36-Series
View: https://www.youtube.com/watch?v=F5Do1wXFliU
