I've used Riva Tuner for a while and had my 8800 GT at 650,1625,950 for a while and just want to do it in Ntune instead.
This is as far as I understand....
You set your overclock and apply it, save it as a profile, and then set it so when Windows starts the overclock is applied. However it never works.
Any help is greatly appreciated.
EDIT:Got it to work with a timer after bootup instead. Any other info on Ntune will be helpful.
