OC Q6600 stress testing help
Page 5 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Wow, thats actually awesome, if it keeps that up!!
Waaahhh, you changed it again!
To go from No load 1.408 to a higher load would be great! It doesnt need that high a voltage till it nears 100% power usage. To reduce itself naturally by a bit like that would prolly be good! but keep it either way!!!
Thats fine!! keep it at one or the other.
Thats now an excellent VDroop!
Remember, it will need right around 1.45 while under full 4 core small fft testing. I used 1.440 on mine, and got it stable with more tinkering at like 1.42x at the same 3.6 So it will be in that range.
You now have like .01 VDroop. Much better than .11!!
--Lupi
what i mean is its best if there is no drop in vcore under any circumstances. because this way you can set the precise vcore the chip is needed to run at certain speed, rather then up excessive vcore to compensate the vdrop and vdroop. can you do a load screenshot will all the monitor ultility open?
I'll have to change vcore up again I'll try 1.40 as IM having a few probs.
Also, I cant get the pc to boot with the 4th memory stick inserted(removed to access resistor). Any ideas on that?
I'm back :)
I let it run for a few days without problems at 3.2 Ghz and 1.425v. Then I today tried to get that 4gb of ram running, so I reset everything to default hoping that would work, but of course it did not.
So I'm stuck with 3GB of ram now, and have no idea why it does not boot with 4 ram sticks inserted, only 3. (I have tried removing different sticks so doesnt seems like its 1 bad stick)
Wow, that is odd. Unless a slot is actually damaged on the board? I dunno. That is very strange. Does it work with just 2 sticks in both sides? As in, Try 2 in the fist colored slots, then take them out if it works, and place them in the other color slots, so you know that a slot isnt damaged..
Maybe someone else will see this and know the problem!
--Lupi
I'll try that later, I am having quite some problems now, most of them has to do with the pc booting. Sometimes it fails to boot at all and you can hear the CPU fan go to max, and sometimes it boots fine but stops at the XP logo, and sometimes it boots fine but it gives me a message saying "Overclocking failed!", and that is after I have put everything in bios back to default. So it's very hard to get it booting normally and mostly I have to try it for 5-10 minutes to get it going...
