CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.1.0
Monitoring
Mainboard Model X470 AORUS ULTRA GAMING-CF (0x000006CE - 0xD99D6852)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8686
LPCIO Revision ID 0x2
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 86 86 02 00 00 20 33 00 00 00 80 40 C8 58 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 40 0A 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A40
Hardware Monitors
Hardware monitor ITE IT8686
Voltage 0 1.30 Volts [0x6C] (CPU VCORE)
Voltage 1 2.04 Volts [0xAA] (VIN1)
Voltage 2 2.03 Volts [0xA9] (VIN2)
Voltage 3 2.04 Volts [0xAA] (VIN3)
Voltage 4 0.84 Volts [0x46] (VIN4)
Voltage 5 0.91 Volts [0x4C] (VIN5)
Voltage 6 1.22 Volts [0x66] (VIN6)
Voltage 7 1.67 Volts [0x8B] (VIN7)
Temperature 0 24 degC (75 degF) [0x18] (TMPIN0)
Temperature 1 29 degC (84 degF) [0x1D] (TMPIN1)
Temperature 2 26 degC (78 degF) [0x1A] (TMPIN2)
Temperature 3 25 degC (77 degF) [0x19] (TMPIN3)
Temperature 4 31 degC (87 degF) [0x1F] (TMPIN4)
Temperature 5 30 degC (86 degF) [0x1E] (TMPIN5)
Fan 0 637 RPM [0x423] (CPU)
Fan 1 446 RPM [0x5E8] (FANIN1)
Fan 4 626 RPM [0x436] (FANIN4)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 10 00 80 DF FF 00 20 FF 98 48 00 30 23 E8 FF
10 FF FF FF 77 C7 D0 C0 C0 04 05 FF FF FF FF FF FF
20 6D AB A9 AA 47 4C 67 8B 7E 18 1D 1A 19 1F 1E 80
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 00 00 00 00
50 FF 18 7F 7F 7F 40 00 00 90 F1 17 12 65 00 00 00
60 00 14 41 46 1C 03 00 00 00 14 3C 46 1C 03 00 FF
70 00 14 3C 46 1C 03 00 3E 00 14 3C 46 1C 03 00 C0
80 FF FF 36 04 FF FF FF FF 00 00 00 00 00 D7 00 DE
90 00 00 00 00 FF 10 30 30 42 99 00 00 01 65 F2 29
A0 00 14 41 46 1C 03 00 D0 7F 7F 96 80 00 00 0F 98
B0 B1 FB 89 7A 7F 7F 8A 00 8A 00 3C 3C 3C 3C 3C 3C
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 0.73 Volts [0x2D5] (GPU)
Power 0 5.93 pc (GPU)
Temperature 0 31 degC (87 degF) [0x1F] (GPU)
Fan 0 0 RPM [0x0] (GPU #0)
Clock Speed 0 300.00 MHz [0x12C] (Graphics)
Clock Speed 1 405.00 MHz [0x195] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
Number of sockets 1
Number of threads 16
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- CCX 1
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
-- Core 6 (ID 6)
-- Thread 12 12
-- Thread 13 13
-- Core 7 (ID 7)
-- Thread 14 14
-- Thread 15 15
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 8 (max 8)
Number of threads 16 (max 16)
Manufacturer AuthenticAMD
Name AMD Ryzen 7 2700X
Codename Pinnacle Ridge
Specification AMD Ryzen 7 2700X Eight-Core Processor
Package Socket AM4 (1331)
CPUID F.8.2
Extended CPUID 17.8
Core Stepping PiR-B2
Technology 12 nm
TDP Limit 105.0 Watts
Tjmax 85.0 °C
Core Speed 4140.3 MHz
Multiplier x Bus Speed 41.25 x 100.4 MHz
Base frequency (cores) 100.4 MHz
Base frequency (ext.) 100.0 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision 0x8008206
L1 Data cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 8 x 64 KBytes, 4-way set associative, 64-byte line size
L2 cache 8 x 512 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 x 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Fh
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 512 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 8 thread(s)
FID/VID Control yes
# of P-States 3
P-State FID 0x894 - VID 0x36 (37.00x - 1.212 V)
P-State FID 0x880 - VID 0x59 (32.00x - 0.994 V)
P-State FID 0xC84 - VID 0x76 (22.00x - 0.812 V)
PStateReg 0x80000000-0x494D8894
PStateReg 0x80000000-0x48164880
PStateReg 0x80000000-0x459D8C84
PStateReg 0x00000000-0x00000000
Package Type 0x2
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Power Unit 0.0
Attached device PCI device at bus 0, device 24, function 0
100 00000000 E0000001 00000000 00000000
110 00000083 00041000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 00000000 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
100 00000000 00000003 00000000 00000000
110 00100000 00100020 00100020 00100000
120 00100000 00000000 00000000 00000000
130 00000000 00000000 00100000 00100020
140 00100020 00000000 00100000 00000000
160 00001020 00000000 00000000 00000000
170 00000000 0000810D 00000000 00008105
180 00000000 00000040 00000000 00000030
190 00000000 00000040 0000003E 00000001
1A0 48201020 00000000 00000000 00000000
1B0 0003040C 00000048 00000040 00000000
1C0 00000020 00000034 01003030 00000000
1E0 00000004 0001014E 00000048 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
130 00010001 00010001 00010001 00010001
140 00010001 00010001 00010001 00010001
Attached device PCI device at bus 0, device 24, function 3
100 00000000 143F1FC2 0380FC40 00000000
Attached device PCI device at bus 0, device 24, function 4
100 00000000 0000015F 000009FF 000002BF
110 00400000 00010000 0001E000 0001FF01
120 0001FF00 00010000 0001FF02 0001FF07
130 0001FF03 00010000 0001FF02 00000000
180 000F0F0F 000F0F0F 001B1B1B 000F0F0F
190 000F0F0F 000F0F0F 00000000 00000000
Attached device PCI device at bus 0, device 24, function 5
100 00000000 04000000 00700281 00000000
190 00000008 00000100 00000000 00000000
1A0 00000000 00000040 00200000 00000000
Attached device PCI device at bus 0, device 24, function 6
130 00000000 00000000 FFFF0000 00000000
140 00000006 00000000 00000000 00000000
1F0 00000000 00000000 00000083 90000000
Attached device PCI device at bus 0, device 24, function 7
SMU Version 43.20.00
TDP/TJMAX 0x690055
TCTL Offset 0xA
Core Perf #0 0x73510462
Temperature 0 31 degC (87 degF) (Package (Node 0))
Voltage 0 1.29 Volts (CPU VDD (Node 0))
Voltage 1 1.29 Volts (VID #0)
Voltage 2 1.30 Volts (VID #1)
Voltage 3 1.30 Volts (VID #2)
Voltage 4 1.29 Volts (VID #3)
Voltage 5 1.30 Volts (VID #4)
Voltage 6 1.30 Volts (VID #5)
Voltage 7 1.30 Volts (VID #6)
Voltage 8 1.30 Volts (VID #7)
Power 00 29.69 W (Package)
Power 01 1.78 W (Core #0)
Power 02 2.56 W (Core #1)
Power 03 1.84 W (Core #2)
Power 04 0.95 W (Core #3)
Power 05 1.70 W (Core #4)
Power 06 1.78 W (Core #5)
Power 07 2.36 W (Core #6)
Power 08 1.91 W (Core #7)
Power 09 14.87 W (Cores)
Clock Speed 0 4140.25 MHz (Core #0)
Clock Speed 1 4140.25 MHz (Core #1)
Clock Speed 2 4140.25 MHz (Core #2)
Clock Speed 3 4140.25 MHz (Core #3)
Clock Speed 4 4140.25 MHz (Core #4)
Clock Speed 5 4140.25 MHz (Core #5)
Clock Speed 6 4140.25 MHz (Core #6)
Clock Speed 7 4140.25 MHz (Core #7)
Core 0 max ratio (effective) 41.5
Core 1 max ratio (effective) 41.5
Core 2 max ratio (effective) 41.5
Core 3 max ratio (effective) 41.5
Core 4 max ratio (effective) 41.5
Core 5 max ratio (effective) 41.5
Core 6 max ratio (effective) 41.5
Core 7 max ratio (effective) 41.5
Storage
Drive 0
Name Samsung SSD 860 EVO 500GB
Revision RVT02B6Q
Serial S4CNNG0KB42793E
Capacity 465.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 465.2 GBytes (38.3 percent available)
Drive 1
Name ST1000DM003-1ER162
Revision CC45
Serial Z4Y9YENW
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume e:\, 638.0 GBytes (87.7 percent available)
Volume f:\, 293.0 GBytes (90.5 percent available)
Drive 2
Name ST1000DM010-2EP102
Revision CC43
Serial Z9ASRPDP
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Volume d:\, 931.5 GBytes (20.1 percent available)
Drive 3
Name USB Drive 3
Capacity 0.9 GB
Type Removable
Bus Type USB (7)
Features
Volume h:\, 0.9 GBytes (50.1 percent available)
USB Devices
USB Device Samengesteld USB-apparaat, class=0x00, subclass=0x00, vendor=0x04D9, product=0xA096
USB Device Samengesteld USB-apparaat, class=0x00, subclass=0x00, vendor=0x09DA, product=0x9090
USB Device USB-apparaat voor massaopslag, class=0x00, subclass=0x00, vendor=0x1307, product=0x0165
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x10A0106
Name NVIDIA GeForce RTX 2060
Board Manufacturer GIGABYTE Technology
Revision A1
Codename TU106-200A
Core family 0x166 (TU106)
Technology 12 nm
Memory size 6 GB
Memory type GDDR6
Memory vendor Micron
PCI device bus 9 (0x9), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x1F08 (0x37D0)
Revision ID 0xA1
Performance Level 0
Core clock 1365.0 MHz
Memory clock 7001.0 MHz
Monitor 0
Model A150X1 ()
ID CMO0150
Serial 0000000001
Manufacturing Date Week 18, Year 2002
Size 15.2 inches
Max Resolution 1024 x 768 @ 60 Hz
Horizontal Freq. Range 28-64 kHz
Vertical Freq. Range 48-78 Hz
Max Pixel Clock 80 MHz
Gamma Factor 1.4
Monitor 1
Model 227E4LH (Philips)
ID PHLC0AC
Serial AU01533001616
Manufacturing Date Week 33, Year 2015
Size 21.7 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-76 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
