Old Compaq 4540 > need help redoing
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.compaq (More info?)
Hello -
I have an old Compaq Presario 4540 I'm trying to set for the kids to
surf on. It will not recongize the hard drive because, I think, it is
too large. the West Digital Lifeguard tools finds it but with a Win98
startup diskette its not recongized so I can't fdisk or format it. Any
thoughts?
Hello,
What size is the hard drive?
JLA ENTERPRISES TECHNOLOGIES INTEGRATION
Technical Support Team
Check out some of the items we are offering
Dell Laptop Docking Stations starting at $5.00
Dell 20" Sony Trinitron Flat Screen Monitors starting at $35.00
Dell 21" Flat Screen Monitors starting at $40.00
Dell Latitude and Inspiron CD Rom and Floppy Drives starting at $5.00
Be sure to visit http://www.jlaenterprises.com
<troadkill@zilligen.com> wrote in message
news:udv9h0lksvt13bipgmfj5442o20gi2gc65@4ax.com...
> Hello -
> thoughts?
hi,
if the drive is too large for your system to recognize you will need
a bios update if available or an ata controller card to recognize the
drive . you could also install the ddo software western digital has
available . you can partition and format the drive using the wd data
lifeguard and the drive overlay software will allow your system to
recognize the drive . you will need to use the special jumper
settings for the overlay to work .
hope this helps ,
terry
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
No BIOS updates are available to overcome the 8GB drive size limit. The 4540
originally shipped with a 3.2GB Bigfoot drive. Get a PCI IDE controller or
try here for a smaller than 8 GBdrive:
http://www.computersurplusoutlet.com/
HH
"terry_b17" <terry_b17@juno-dot-com.no-spam.invalid> wrote in message
news:41158e55$1_2@news.athenanews.com...
> hi,
> hope this helps ,
> terry
Yep.Go with the PCI IDE controller.
HH
news:glgmh0d1mgd2smn2gcegrlqke2kt174kbl@4ax.com...
> Thanks for the suggestions. It is 40 gig drive - sounds like it is too
> big.
4540
or
> >HH
> >> hi,
> >> hope this helps ,
> >> terry
