Archived from groups: alt.comp.hardware.homebuilt (
More info?)
On Thu, 29 Apr 2004 05:01:38 -0700, joe_s@nospam.com wrote:
>On Sun, 25 Apr 2004 10:54:05 -0400, Gary Tait <classicsat@yahoo.com>
>wrote:
>>On Sat, 24 Apr 2004 04:24:38 -0700, joe_s@nospam.com wrote:
>>>My new motherboard has a spdif in/out header on the motherboard.
>>>Was just wondering if the old digital out two pin connector on my
>>>toshiba sd-m1402 DVDRom is capable of supplying cleaner audio to the
>>>motherboard audio through the spdif in header ? The spdif cable fits
>>>both, but I'm wondering if both are on the same page technologically
>>>speaking
>>Yes, they are the same signal. It will most likely be better than the
>>analog cables, and quite possibly that digital audio over the IDE bus.
>>*Do realiize that that auidio is for audio CDs only, the audio from
>>DVDs comes off the IDE with the video, and is decoded in your player
>>software.
>Thanks for the info. I'll try it out, but since I don't listen to too
>many audio CD's, it'd probably be a waste of a good audio input
>You wouldn't know where I can find the header cable/pci slot cover for
>the spdif I/O would you ?
Audio from an optical drive (other than that in a file such as a DVD or
other video format) can be transferred over the PCI bus with zero quality
loss... that's the whole point of digital, it makes no difference how it
gets to it's destination so far as quality is concerned.
If you can't find the header cable for your board you might start by
noting the motherboard's pin-header configuration and go from there.
Another make of (motherboard) optical dongle may work as-is or after
swapping a position of the wires in the connector, providing connector has
proper # of rows/columns. Another option is to make your own, relatively
easy since anyone could drill a suitable hole in a slot cover bracket,
attach an RCA jack or two and solder two wires to an appropriate
pin-header socket, if they're inclined to do so.
