[SOLVED] One 8 pin and one 4 pin connector for cpu
bashenderiks
43
Hello,
I just got my new motherboard, and saw it has one 8 pin and one 4 pin connector for the cpu. My Corsair rm650 only has one 8 pin connector that I can connect. Do I now need to buy a whole new power supply or is there another way??
Kind regards.
First of all the extra 4 pin connector may not be necessary.
The extra eps power is used for powering a second pcie slot for sli as well as for overclocking and for the power required for a cpu such as the i9-9900K
Likely, your motherboard manual will discuss when and if the extra 4 pin eps lead is necessary.
If you find that you need one, there are adapter cables that you can use.
It might look like this:
https://www.newegg.com/Product/Product.aspx?Item=N82E16812423185&Description=molex to atx&cm_re=molex_to_atx--12-423-185--Product
I have one in the garage for another family build. Good board.
Since your PSU is modular, you might be able to order a 4-pin cable from Corsair.
yeah, but the problem is my psu only has one place to put a 8 pin, so I can't put a second 8 pin in
okay thx and then you put the molex cable back in the psu?
