[SOLVED] ONLY the right arrow key doesn't work on my keyboard. (Not a Hardware problem)
DriftKing1234
40
Hello,
so this problem recently just popped up, first it was just the right arrow key, then the Num Pad also stopped working, just the right arrow key by the way.
I know that it is not a hardware problem because the keyboard software on windows 10 doesn't work either and also in the BIOS everything works normally. Of course only the right arrow key doesn't work. Some kind of software has to be denying my right arrow key input for some reason. The funny thing is that CTRL + Right arrow works just fine. Also Num Pad right arrow doesn't work but with CTRL it works again. I really don't even know where to start troubleshooting. It can't be a virus either, I tried running multiple scanners and they all didn't find anything.
So to the experts or anyone who had this problem as well, I would really appreciate your help.
Thanks a lot.
