FormatC :
@vulcan78
I compared the TitanXP with the 1080 Ti in the lab, screw by screw, the 1080 is totally uninteresting in this comparison. And BTW; the linked review is more or less totally worthless, because there I missed the most the important data and any technical details about the coolers. I wrote you above, why this cards are similar (both cards are coming from PNY's same insertion line in China mainland) and where you can find the (small) differences.
If you have a problem to understand technical basics and why refurbished iron can't be so significant better, it is your problem. My one and only problem is to believe PR bubbles if I know the details and the background simply better. I have all three cards here - the Quadro P6000 with the uncrippled chip too. Same cooler under the hood (but other cover design) - similar cooling performance. And it is only one call to a factory to get closer info which parts are used.
Your video is entertaining, the typical YT posing with a lot of blah blah instead of any professional measured data. You are invited to visit my lab and my semi-anechoic chamber (room-in-a-room, calibrated microphones and professional audio-software) to understand the basics of an exact, scientific work and to compare this small Asetek midget with a real water cooling solution and high-end fans.
The small Asetek pump is hearable (high pitch), the hybrid fan too (especially in idle!) and the 120mm fan is not a pain but the typical 5 USD standard crap from China. If someone is believing this is quiet he must be simply deaf. I've tested a Kraken X40/G10 in my lab long time ago and it is - as I said - a toy. Closed loop, not more. On a R9 290 I've measured three years ago 37,2 dB(A) in a distance of 50 cm, this IS noisy, if you can have the same thing with a level below 31 dB(A). THIS is nearly unhearable in the most rooms. A water cooler is only good, if you can think that the computer is switched off.
Physics isn't a bitch. If you are satisfied with this, why not? But never write about things that you have never owned, tested or measured. If you never tried a Mercedes, you will really think, a VW Rabbit would be the best car you can buy.
the classic Nvidia aesthetic lighting flavor
To be honest, but you are the typical Nvidia marketing victim. But it is the best proof, that their PR is working well
@anbello262:
I can't read any facts and arguments from his side, only insults and malicious allegations. And I'm sure he was searching only a chance to push his funny YT video and other websites. Or it is in real a paid Nvidia PR. It is a waste of time to bring facts if a guy not even can't understand the difference between duty cycle in percent and real speed in rpm. This are simply basics. Elementary school level.
I moved from the H55 to an X41, which is much thicker and whose fan I could run at 50% RPM, which was inaudible, with load temps <45C.
But that was before, have a look at my post above, where my 1080 Ti wont get above 67C under full load sustained with +150 core / + 500 memory, default voltage. If I set the fan to 60%, which is much more bearable, the temps don't exceed 78C, which is admittedly warm and far from inaudible, if I set the fan to 100% the temps don't exceed 58C with the overclock.
I just wanted to post back because part of your argument was that 1080 Ti FE runs too hot (84C!) and needs $400 in liquid cooling. Well, aside from The Witcher 3 in 3D Vision (for whatever reason) 2D titles the clocks don't drop under 2000MHz unless it exceeds 70C, which I've seen it do with a less aggressive fan algorithm. At 70% RPM the temps stabilize at 72C. At 68C the fan RPM hit's 78% and it really doesn't go higher than that.
67C and clocks over 2000Mhz stable with a little bit of noise and I can save that $400 and put it forward my next upgrade, which I don't believe will happen for a good long while as I'm satisfied with 2560x1440.
Yeah, I can hear the fan at night with a game with ambiance such as Fallout 4 when the background music stops playing, but in the day, say playing Titanfall 2, I can't hear it over the headphones to be perfectly honest. Positioning the PC under the table helps, maybe everyone complaining about the noise has their PC mounted on their table 2.5 feet from their head.
$700 1080 Ti FE ~= $1200 Titan XP with a water-block and $400 liquid cooling set-up performance wise, acoustics aside.
Put up your benches without your shunt mod:
http://www.3dmark.com/fs/12009294
http://www.3dmark.com/fs/12011832
100% Rock solid stable, zero display driver crashes, zero artifacts.
Oh and so much for "The Paragon demo with the 1080 Ti running at 67C overclocked was pure PR"
LMFAO.
If you want I will post a video with it not exceeding 58C at 2025 core and 6GHz memory with the fan at 100% RPM. So yeah, 67C isn't even the full performance potential of this card on air.
Try that with Titan XP, as you said, and refuse to retract, "there is no difference between Titan XP and 1080 Ti FE cooling-wise, they both need liquid cooling".
"No difference" comparison across 18 games, all three cards using reference cooler:
http://www.overclock.net/t/1624521/nvidia-gtx-1080-ti-owners-thread/800_100
Tad long post, but thought I would share some benching I did most of today between 1080's and 1080Ti's both FE to see how they compare at stock and overclocked with a few Titan X Maxwell Scores sprinkled in.
System Specs used: 5960x @ 4.6 Ghz, Cache @ 4.4 Ghz, 32GB RAM @ 14-17-17-34 1T
Panel used was the ASUS PG348Q, so 3440 x 1440 with V-Sync and G-Sync off in everything.
All cards used a 1:1 fan profile
GTX 1080Ti
Stock settings average boost 1860 Mhz Core / 11,016 Memory
Overclocked settings average boost 2002 Mhz / 12,000 MHz Memory
GTX 1080
Stock settings average boost 1848 Mhz Core / 10,012 Memory
Overclocked settings average boost 2075 Mhz / 11,000 MHz Memory
Titan X (Maxwell, EVGA SC BIOS)
Stock settings average boost 1316 Mhz Core / 7,012 Memory
Overclocked settings average boost 1474 Mhz / 8,020 MHz Memory
% increase and decrease is based on my stock 1080 scores. FPS are Averages
OVERALL AVERAGES ACROSS THE BENCHMARKS
GTX 1080: BASELINE
GTX 1080 OC'd: 9.98 % increase
GTX 1080Ti: 29.5% increase
GTX 1080 OC'd: 39.3% increase
Titan X: 12.2% Decrease
Titan X OC'd: 3.1% Decrease
Overall stock 1080Ti is 30% ahead or so of stock 1080 and similar for overlocked 1080Ti vs 1080. Gap is smaller, when we strip out synthetics which will scale better then games mostly. Now to see how SLI 1080 vs SLI 180Ti compares smile.gif
Far Cry Primal - Ultra Preset + HD Pack
GTX 1080: 60 FPS
GTX 1080 OC'd: 67 FPS (11.6% Increase)
GTX 1080Ti: 80 FPS (33% increase)
GTX 1080 OC'd: 87 FPS (45% increase)
Titan X: Average: 53 (11.7% Decrease)
Titan X OC'd: Average: 59 (2% Decrease)
Ghost Recon Wildland - Very High Preset
GTX 1080: 57.5 FPS
GTX 1080 OC'd: 61.21 FPS (6.5% increase)
GTX 1080Ti: 71.25 FPS (23.9% increase)
GTX 1080 OC'd: 76.59 FPS (33.2% increase)
Ash’s of the Singularity GPU Test - DX11 - Extreme Preset
GTX 1080: 57.5 FPS
GTA 5 - All settings Maxed but no MSAA on anything
GTX 1080: 71 FPS
GTX 1080 OC'd: 83.1 FPS (15.7% increase)
GTX 1080Ti: 88 FPS (22.6% increase)
GTX 1080 OC'd: 94.8 FPS (32% increase
Titan X: 64.34 FPS (10.4% Decrease)
Titan X OC'd: 72.5 FPS (1% increase)
Arkham Knight - All settings maxed, No gamework settings on
GTX 1080:84 FPS
GTX 1080 OC'd: 91 FPS (8.3% increase)
GTX 1080Ti: 103 FPS (22.6% increase)
GTX 1080 OC'd: 116 FPS (38.1% increase)
Tomb Raider - Ultimate Preset
GTX 1080: 98.2 FPS
GTX 1080 OC'd: 108 FPS (10% increase)
GTX 1080Ti: 131.9 FPS (34% increase)
GTX 1080 OC'd: 141 FPS (44.5% increase)
Titan X: 88 FPS (10.4% Decrease)
Titan X OC'd: 96 FPS (2.3% decrease)
Dues Ex mankind Divided - Ultra Preset no MSAA
GTX 1080: 41.3 FPS
GTX 1080 OC'd: 45.6 FPS (10.4% increase)
GTX 1080Ti: 55.3 FPS (33.9% increase)
GTX 1080 OC'd: 62.1 GPS (50.4% increase
Dragon Age inquisition - Ultra Preset
GTX 1080: 72.4 FPS
GTX 1080 OC'd: 79.6 FPS (9.9% increase)
GTX 1080Ti: 89.1 FPS (23.1% increase)
GTX 1080 OC'd: 102 FPS (40.1% increase)
Titan X: 60.5 FPS (16.4% Decrease)
Titan X OC'd: 68 FPS (6.1% Decrease)
Witcher 3 - High Post processing Preset and Ultra Graphical quality Preset - Novigrad loop
GTX 1080: 54 FPS
GTX 1080 OC'd: 60 FPS (11% increase)
GTX 1080Ti: 67 FPS (24.1% increase)
GTX 1080 OC'd: 72 FPS (33.3% increase)
Titan X: 49 FPS (9.3% Decrease)
Titan X OC'd: 52 FPS (3.1% Decrease)
Witcher 3 - High Post processing Preset and Ultra Graphical quality Preset - Skelliga crossroads trees / forests loop
GTX 1080: 49 FPS
GTX 1080 OC'd: 51 FPS (4.1% increase)
GTX 1080Ti: 59 FPS (20.4% increase)
GTX 1080 OC'd: 63 FPS (28.6% increase)
Titan X: 43 FPS (12% Decrease)
Titan X OC'd: 47 FPS (4.1% Decrease)
Witcher 3 - High Post processing Preset and Ultra Graphical quality Preset - Beauclair castle balcony loop (Long Vista)
GTX 1080: 67 FPS
GTX 1080 OC'd: 72 FPS (7.5% increase)
GTX 1080Ti: 82 FPS (22.4% increase)
GTX 1080 OC'd: 87 FPS (29.9% increase)
Titan X: 60 FPS (10.4% decrease)
Titan X OC'd: 65 FPS (3% Decrease)
Hitman Absolution - Ultra - 2 x MSAA
GTX 1080: 81.1 FPS
GTX 1080 OC'd: 92.6 FPS (14.1% increase)
GTX 1080Ti: 103.2 FPS (27% increase
GTX 1080 OC'd: 113 FPS (39% increase)
Titan X: 68.4 FPS (15.7% Decrease)
Titan X OC'd: 78.1 FPS (3.7% Decrease)
Shadow of Mordor - Ultra Preset
GTX 1080: 94.95 FPS
GTX 1080 OC'd: 107.19 FPS (12.9% increase)
GTX 1080Ti: 116.06 FPS (22.2% increase)
GTX 1080 OC'd: 127.06 (33.8% increase)
Titan X: 81.2 FPS (14.5% Decrease)
Titan X OC'd: 92.6 FPS (2.5% Decrease)
Total War Warhammer - Ultra Preset
GTX 1080: 68 FPS
GTX 1080 OC'd: 78.2 FPS (15% increase)
GTX 1080Ti: 96.71 FPS (42.2%)
GTX 1080 OC'd: 103 FPS (51.5% increase)
Metro Last Light Redux - All settings Maxed No Motion Blur
GTX 1080: 38.1 FPS
GTX 1080 OC'd: 41.14 FPS (8% increase)
GTX 1080Ti: 49.91 FPS (31% increase)
GTX 1080 OC'd: 56 FPS (47% increase)
Vally Benchmark - Extreme HD Preset resolution at 1440p
GTX 1080: 66.1 FPS
GTX 1080 OC'd: 70.5 FPS (6.7% increase)
GTX 1080Ti: 89.9 FPS (36% increase)
GTX 1080 OC'd: 97.3 FPS (47% increase)
Firestrike
GTX 1080: Graphics Score: 20800
GTX 1080 OC'd: Graphics Score: 23700 (13.9% increase)
GTX 1080Ti: Graphics Score: 27417 (31.8% increase)
GTX 1080 OC'd: Graphics score 29050 (39.7% increase)
Firestrike Extreme
GTX 1080: Graphics Score: 9721
GTX 1080 OC'd: Graphics Score: 11451 (17.8% increase)
GTX 1080Ti: Graphics Score: 13465 (38.4% increase)
GTX 1080 OC'd: Graphics Score: 14525 (49.4% increase)
Firestrike Ultra
GTX 1080: Graphics Score: 4917
GTX 1080 OC'd: Graphics Score: 5624 (14.4% increase)
GTX 1080Ti: Graphics Score: 6808 (38.5% increase)
GTX 1080 OC'd: Graphics Score: 7109 (44.6% increase)
