Overheating and restartin of my pc
cool007arora
8
i bought a pc 2 months back and m having some major problems which are increasing day by day
my pc confrigation are
core i7 930
1 gb ati radeoon 5770 ddr5 graphic card
4 gb ddr3 ram
500w stock psu
1 tb hdd
during fst month my pc restarts after an hour or two while i play games
technician advised me to change my cabinet so i changed and then there were no problems
bt from last 2 weeks m having some unpredictable problems , it shutdowns or restarts in unpredictable time whether 2 mins , 1 hour , 4 hour or none..
sometimes it shows msg " ur pc is overheating due to thermal event "
sometimes nothin ,it jus shutdowns...
main problems is that overheatin is caused when pc works for 5-6 hours bt sometimes my pc restarts in 2 mins and then also it shows this msg
how is it possible tht without any load or work it overheat
i asked technician he said somethin is wrong with graphic card
i dont think so
coz without any load it restars
plzzz help me regardin this issue
coz its my new expensive pc and i dont want it to b lyk tht
As your warning message says 'due to thermal event',
First thing I'd do is check its clean inside, I know its not an old unit, but depending on where it lives it may be a dust haven, best to make sure your not clogged up already hehe,
secondly, how many fans are in there? might need more fitted
and it may also be an issue that the heatsink on the psu is causing,
give us some feedback, and pictures of the unit if possible please.
Moto
Moto
as u said i contacted my vendur
\and he said problem is with my gpu so he removed my gpu and placed 256 mb nvidia gpu for test
and after tht my cpu temp is constant from 40 to 50
and now no restarts , overheats happenin
so is the prob with gpu?
If the problem does lie with the graphics card its still their duty to resolve the issue, (assuming it was fitted as part of the original sale and not put in by you afterwards)
you bought what you expected to be a fully functioning system from a reputable? vendor,
great job so far in that they've identified (hopefully) the issue,
time to carry the good service on by making sure your rig works as it should, I'm not sure what your region has as consumer protection, but in the uk we have laws to try and protect you in circumstances like this,
let me know how you get on man.
Moto
