I've had a look around and this seems like quite a popular problem, however none of the answers have worked for me
All parts are entirely brand new straight out of the packaging. I'd just finished building it together, but to no avail.
So I've cleared the CMOS, no dice. Turned on without RAM, no beeps at all. Not sure if there's an on-board speaker but I put my headphones in the jack and no beeps. Bench-tested with just the MoBo, GPU, CPU, HSF, RAM, Keyboard and monitor, but still no dice. MoBo light is green. Every single fan works perfectly.
Testing
Monitor- Both my 2243BW's work fine through my laptop, so they're clean.
GPU- When I pull the graph. card out there's still no beeps. I don't have another one to test this, so I'm just assuming here.
RAM- I've got 2x 2GB sticks, I've checked with both of them and none of them and a single one, then the other and still nothing.
Speakers- work perfectly through my iPod and laptop, so they're fine
MoBo- I'm guessing the problem might lie here. I don't have a case speaker or a motherboard speaker attached, because I'm guessing a $230 AUD motherboard would have something of the sort set out.
CPU- Here's my other hunch. However it gets hot to touch the CPU once it's been on for a while, so it seems to be working?
Could it be a short-circuit? I've set it up on the cardboard box and there's no screws or anything wedged in anywhere...
Should I organize to send my MoBo or CPU back to the retailer for a replacement, or can I fix it here?
BTW, it's my first shot at building a comp.
Specs if it would help:
CPU: Intel E8400
Motherboard: Asus P5Q3
GPU: Powercolor HD 4890
RAM: 2GB sticks of Kingston 1333 DDR3
PSU: Thermaltake TR2-550w. (one other thing- it's only got a 4-pin connector for the power, should I change it to get something with an 8-pin one?
Testing
CPU: Intel E8400
