Hello,
I got my hands on a defective Gigabyte RTX 3090 Vision OC. I tested it on my mainboard beforehands and it seems to fried my mainboard (but thats another task...)
I was able to found the error, it was a defective/burnt MOSFTET and one small SMD capacitor was shorted and one resistor missing. After removing the MOSFET and capacitor, the GPU seems to work again.
Now I have two questions: Do I really need to replace the Mosfet+Capacitor? I know I am now missing one Phase on the GPU power rail but is it THAT bad? How much instability might occur or is it just going to perform worse?
Second and most important question: Does someone have the exact part number of the MOSFET and maybe capacitor and resistor values? It's the 3rd MOSFET from top on the right side (see image). I wasn't able to read it since the chip was quite burnt and I even had to dremel off some parts. Or maybe someone could provide some high resolution images of said area?
Thank you!
![hLQddL1.png](https://i.imgur.com/hLQddL1.png)
Thank you!
