[SOLVED] Parts compatibility for NZXT H1 Mini-ITX
Jul 1, 2020
Hi all,
Building my first PC and have decided to use the NZXT H1 as the case.
I've got a list of potential products which all seem to be fine together but just wanted to double check here. Particularly in terms of physical restrictions of the case but also i.e. matching ram speed to processor speed.
Motherboard: Gigabyte AMD B550 AORUS PRO AX Mini-ITX
Processor: AMD Ryzen 5 3600 Gen3 6 Core AM4 CPU/Processor with Wraith Stealth Cooler
RAM: Corsair Vengeance LPX Black 16GB 3600 MHz AMD Ryzen Tuned DDR4 Memory Kit
SSD:Samsung 970 EVO PLUS 250GB M.2 NVMe PCIe High Performance NVMe SSD/Solid State Drive
GPU: Gigabyte NVIDIA GeForce RTX 2060 6GB WINDFORCE OC V2 Turing Graphics Card
Any help would be very much appreciated & if you have any recommendations on the parts above. I've done some research into them and they seem to come out fairly strongly vs intel equivalents.
Thanks!
Looks OK to me.
I might opt for at least a 500gb or 1tb ssd.
FWIW:
MY build process:
Before anything, while waiting for your parts to be delivered, download
and read, cover to cover your case and motherboard manual.
Buy a #2 magnetic tip philips screwdriver.
I find it handy to buy a power switch like this for testing.
https://www.ebay.com/p/4in1-PC-Powe...or-Computer/631889283?iid=142232821294&chn=ps
1. I assemble the critical parts outside of the case.
That lets me test them for functionality easily.
A wood table or cardboard is fine.
2. Plug in only the necessary parts at first. Ram, cpu, cooler, psu.
Do not force anything. Parts fit only one way.
Attach a monitor to...
Looks OK to me.
FWIW:
MY build process:
Attach a monitor to the integrated motherboard adapter if you have one, otherwise to the graphics card.
  1. If your motherboard does not have a PWR button, momentarily touch the two pwr front panel pins with a flat blade screwdriver.
  2. Repeatedly hit F2 or DEL, and that should get you into the bios display.
  3. Boot from a cd or usb stick with memtest86 on it. memtest will exercise your ram and cpu functionality.
  4. Install windows.
  5. Install the motherboard cd drivers. Particularly the lan drivers so you can access the internet.
Do not select the easy install option, or you will get a bunch of utilities and trialware that you don't want. Drivers only.
  1. Connect to the internet and install an antivirus program. Microsoft security essentials is free, easy, and unobtrusive.
  2. Install your graphics card and driver if you tested with integrated graphics.
You will need to remove the graphics card later to install your motherboard in the case.
As a tip when screwing the motherboard into the posts, give the screw a small counterclockwise turn until you feel a click.
That lets you know that the screw will engage properly.
Make a note of how the graphics card latches into the pcie slot.
The mechanism will be hidden under the card and may be difficult to work if you have not previously checked how.
  1. Update windows to currency.
  2. Only now do I take apart what I need to and install it in the case.
  3. Now is the time to reinstall your graphics card.
Reactions: stefthegreek
Looks OK to me.
FWIW:
MY build process:
  4. Install windows.
Thanks for this and the tips! Need a screwdriver definitely.
