[SOLVED] Pc build (advice)
Dec 5, 2020
Hello everyone,
As the title says I am in need of help with building my pc. I recently bought the 3060 rtx and was wondering what kind of cpu, psu and RAM I need to not let it bottleneck.
Thank you already for your help.
Games I want to play: ARK, COD, TOTAL WARHAMMAR 2, and alot more...
Budget:1500 euro
PC
Pc Case: Phanteks Eclipse P400 Tempered Glass Black Midi Tower Behuizing
GPU: 3060 TI
SSD: Kingston A2000 1000GB M.2 SSD
CPU : AMD ryzen 5 3600/ Intel Core i5 10400/ intel core i7 9700k
motherboard: asus b550 moederbord
CPU cooler: Cooler Master Hyper 212 Evo
extra fans: Arctic P12 PWM PST Value Pack/
RAM: Corsair Vengeance 8 GB, DDR4, 2666 MHz 8GB
PSU: ?
It's a good build overall but there are a couple of things I would change up.
8GB of RAM seems a little unfortunate for a build with such a strong CPU/GPU combo like this. Specially since games like CoD will require most than 8GB most of the time (I usually sit at around 10-11GB with CoD and Discord on). Having 8GB will cause stutters and affect your gaming experience. I would strongly recommend 16GB. You can benefit from Dual Channel memory by using a 2x8GB kit, which will provide more FPS.
Moreover, a speed of 2666MHz is a little bit slow in my opinion. Since this is an AMD CPU it relies on fast RAM for good performance. You are sacrificing performance here. It's recommended to opt for 3600MHz for Ryzen 3rd Gen but at the very least...
Moreover, a speed of 2666MHz is a little bit slow in my opinion. Since this is an AMD CPU it relies on fast RAM for good performance. You are sacrificing performance here. It's recommended to opt for 3600MHz for Ryzen 3rd Gen but at the very least 3200MHz as a minimum.
You can use the money you save up from not buying the Hyper 212 Evo cooler and invest it in the RAM because the included Wraith Spire cooler that comes with the CPU is just as good.
Apart from that, everything else looks good to me. Personally since games don't benefit from NVMe-speed SSD's; I would opt for a 500GB SSD to install Windows, all your programs, software, game launchers, and then get a 1TB regular Sata III SSD to store your games in. But what you've picked is more than reasonable.
I don't know in which country you're in, but this is the build I would go for (see PSU in this list) although it would be nice to know whether the RTX 3060 Ti is included in the price or not:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor (€249.99 @ ARLT)
Motherboard: Asus TUF GAMING B550-PLUS ATX AM4 Motherboard (€131.89 @ Alza)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (€63.90 @ Amazon Deutschland)
Storage: ADATA XPG SX8200 Pro 512 GB M.2-2280 NVME Solid State Drive (€68.90 @ Amazon Deutschland)
Storage: Team GX2 1 TB 2.5" Solid State Drive (€77.59 @ Amazon Deutschland)
Video Card: Zotac GeForce RTX 3060 Ti 8 GB Twin Edge OC Video Card (€689.00 @ Amazon Deutschland)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case (€89.90 @ Amazon Deutschland)
Power Supply: SeaSonic FOCUS 650 W 80+ Gold Certified Fully Modular ATX Power Supply (€98.97 @ Amazon Deutschland)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan (€5.39 @ Amazon Deutschland)
Total: €1486.31
Generated by PCPartPicker 2020-12-05 21:29 CET+0100
Let me know what you think.
Thanks for your advice, what CPU would u choose cause the AMD ryzen is a bit overpriced in my opinion (btw i live in the Netherlands) and the rtx 3060 ti is included in the price.
