Question Pc crashed, won’t post
Apr 1, 2021
I was in the middle of a csgo game and my pc randomly shut off, when I turned it back on, my 2 radiator fans and the 3 front case fans spun but the back and 2 bottom fans spun for 2 seconds if that and stopped. Everything lit up fine. But pc would not post. I had read that it could be a psu issue so I sent it back and just received my new one but the problem consists. Everything except my gpu is a month old.
Here are the specs:
Ryzen 5 5600x
EVGA Gtx 1070 FTW
Corsair Crystal 680x Case RGB
32gb Corsair Vengeance RGB Ram
Samsung Evo plus 500gb M.2 SSD
Sabrent Rocket 1TB M.2 SSD (PCIe Gen4)
Corsair H100i RGB Platinum SE CPU AIO
Seasonic Focus 850W 80+ Gold PSU
ASUS ROG Strix B550-A Motherboard
You might want to breadboard the system with only the bare minimum, i.e, one stick of ram, only the boot drive and the GPU on the first PCIe slot, see if you get any response from the system. It could be that the board might've conked out.
Ah no such luck I went ahead and started a RMA on my mobo hopefully that fixes the issue thanks.
