So I am having some very annoying issues with my PC. It randomly freezes where I can no longer move my mouse, talk to people on discord or hear any audio (the audio always stops like 10 seconds after everything freezes). The only fix for this issue is to hold down the power button on my case (or unplug it or whatever) and reboot, after that it seems fine again.
Another issue I am having is my PC becoming very slow. This rarely happens in games, but does happen sometimes when watching a video. I will notice the video stuttering, but not having to load so I know its not my internet. There will be these stutters or mini freezes, where audio will also lag or sound robotic during those freezes. These freezes will happen for a minute or 2, until a longer freeze happens, my monitors lose signal and my PC restarts.
Sometimes after a freeze or forced reboot, when I turn the PC back on my second monitor (both are connected through displayport), will stay black. It is recognized by windows as a 2nd monitor but not receiving signal. I will then unplug the displayport cable, notice Windows swapping to single monitor mode and plug it back in. This resolves the issue, but might be an indicator to someone as to what is wrong with my PC.
Today I also had the first Blue screen I have seen. It might have happened before (maybe during those forced restarts) but because I lose signal to my monitors most of the time I maybe just cant see the actual blue screen. I checked the reliability monitor and will post some screen shots below through imgur:
Things I have tried:
PC Specs:
I would be happy to send more screenshots or give more information, but am not sure what other information to give for now, so please ask if something is missing or you are curious about something that might be causing it. Would be happy to do some troubleshooting. If it is obvious it is a defect part, I am also willing to replace it, but I am not 100% sure what part could be the issue right now. Hope its not my GPU so I can wait for the 5000 series
- Windows CMD check for corrupted or damaged/missing system files (non found);
- Windows upgrade and fresh install;
- Removing some lesser used applications;
- Closing almost all applications and disabling them to automatically launch on startup to try and isolate the issue (was not able to link the issues to a single application);
- Checking connections in the PC (cables and such);
- Monitoring temps (no overheating seems to be happening);
- Trying different monitors (tried 2x HDMI monitors, a TV, 2x Displayport monitors, 1x DP 1x HDMI, ultrawide), none of which had any impact;
- Read about alt-tabbing to certain applications causing similar issues for some people, so stopped alt-tabbing for a while (issue still happened after closing a game for example or when randomly just watching a video);
- Upgrading all drivers and uninstalling drivers I no longer use.
PC Specs:
- Windows version: Win11 Home 23H2
- MB: TUF GAMING B550-PLUS-WIFI 2 (wifi adapter not connected, directly connected to the router (fiber))
- CPU: Ryzen 7 5800x3d
- GPU: MSI RTX 3070 VENTUS 3X OC
- RAM: G.Skill DDR4 3600MHz (2x8GB)
- Drives:
- C: Samsung 850 EVO 250GB
- D: WDC HDD 465GB
- E: WDC HDD 1.5TB
- F: Samsung 980 PRO 2TB (boot drive)
