Question Pc restarts randomly - Kernel power 41 error
Jethro_2200
Commendable
Dec 20, 2021
15
I just made my pc and i thought it was my psu before so i sent it back and got a new one. I just reinstalled it today and it still restarts by itself. I have tried updating my drivers, windows and bios and turned off the auto restart in windows. What do i do?
Cpu - Ryzen 5 5600g
Gpu - Gigabyte 1660 Oc
Psu - Corsair Cx 550-f
Motherboard - Msi pro vdh -wifi b550m
Ram - G skill ripjaws 16gb (2x8) 3200mhz
Storage - Kingston nvme m.2 NV1 1tb
Case- Corsair 275r Airflow
This is most likely a problem with the on/off and/or reset switch on your case. There is a way to take the switch completely out of the equation for testing purposes. If this isn't the problem, and it's not overheating, then it could be anything from RAM to MOBO at this point.
Do i just unplug the reset switch
Vgk.sys would point to the game Valorant? Are you having a BSOD if so can you check reliability history, and open the bluescreen dump files with WinDbg as admin (may need Microsoft store install) and post here.
If you struggle with this let me know.
https://answers.microsoft.com/en-us...eat-file/86c67c5c-0eb3-4333-b08c-82c834606460
I reinstalled valorant and it was fine but when i play steam games like csgo or apex or epic games like fortnite it restarts. But not with valorant.
also i went through my event logs again and i found this error
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
should i try and reinstall windows?
