Please read the whole post to understand the problem
My UPS is powerguard 1200va UPS, they're saying it's 720watt
I have corsair cx650W PSU (Today bought this PSU cause older one was causing problem,the current problem , Also it was causing pc to restart while gaming) running rx590 with it
Whenever gpu using more than 170 watt, and then if poweroutage happens/if i turn off main switch of the UPS.
Pc doesn't run on the battery, it restart's but UPS is still turned on
But GPU is pulling less than 170 then if i turn off main power pc runs on the battery doesn't cause any restart.
Though another thing, when pc is idle, if i turn off main power of the ups pc is running on the battery, now if i start gaming/benchmarking which causes
GPU to pull more than 170watt pc is still running on the battery, UPS isn't shutting down,
So i have two guesses, Maybe UPS is faulty and it's delaying ? or maybe PSU's capacitor isn't that big to hold power during UPS is changing AC to DC?
Or any other problem? that's why i'm posting this cause i can't just go and buy another UPS, firstly i've to be sure
