PC - Satellite P105-S6064- won't boot; Power Light flashes once but Optical Drive light flickers endlessly.
145
Hello. I recently changed my HDD (over a month though) and it has been doing just fine, off course there would be this issue and that. But the focus of my post is a recent problem I encountered while surfing the net and browsing some files: the Optical Drive gave a sound and upon checking, only 'C:/', 'DVD RW DRIVE (D:/)' were present and 'CD Drive (E:/)' was missing (all of this, though there wasn't a disc inside the drive was baffling); PC suddenly turned blue with some white-black horizontal lines moving up, just like on an unset TV; it continued until I force-shutdown the thing and after some seconds when I tried to power it on, the power light flashed once and was off again but the optical drive kept flickering as it does when a DVD/CD is inserted.
I checked the HDD and RAM to see if it they were hot, but warmth degree was negligible-the RAM was even less- then next I checked the screen cable but found it connected. After fixing everything back and pressing the power key, the PC was on again?!
Session was lost but it was working again. This morning upon pressing the power key again I was able to work on my computer until it repeated the blue-screen.... I can't remember if I forced it to shutdown, but I was able to use it after some minutes.
Note: The blue screen wasn't a BSOD as it was purplish and not purely blue, and darker too.
-The missing 'CD Drive E:/' occasionally presented itself when I checked 'Computer' and Optical Drive light would flicker, but this is the time everything would stop.
-After turning on the PC, 'Opera' browser as I was using it, would 'glow' the desktop wallpaper as if it was set in transparency mode for short milliseconds and after about 5secs. would be back to normal.
-I have recently installed Puppy Linux (Slacko 6.3._) as a backup OS after checking it using a Live USB, so I could retrieve my files in case anything goes wrong with Windows. It might not be the problem, but I think its worth noting. And there's also a free 1022 or 1024 MB if free partition left after installing Puppy.
-I use Plop boot manager.
-RAM= 2GB.
-HDD= 500GB.
-Its a Windows 7, x32 bit PC.
HOPE THE DETAILS WOULD BE INFORMATIVE ENOUGH TO TROUBLESHOOT THE COMPUTER.
Only way to know for sure is swap out parts. Most shops have battery, HD, CD drive, spare power cord, memory, monitor to test. If none of those fix the problem then they know its the motherboard needing replacement.
Its the peice in the picture the fingers are holding onto. Most are removable and can be put on a new drive. You simply take it off and snap it onto the replacement.
It won't turn on again. The battery got low while in sleep mode, the HDD LED kept blinking faintly and the Optical Drive light too. I recharged it later but when I left it again in sleep mode, the original problem re-occured and I pressed the power key to login; the screen soon became colored and laptop siin shut itself down, the Optical Drive light still blinking. I didn't reply sooner because I was backing up my phone data; I MOVED some of the files in my phone to the PC so I could make some space for the backup; but now its OFF. I really hope I can get'em back soon.
Try making a Hiren's boot USB. Use this tool and its simple to make. Just select Hiren boot CD in step 2 and then your USB drive.
https://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
Then at start hit your boot menu function key or set bios to boot from USB. It should start into a windows xp gui. You have access to all kinds of test software to check every part. It should look like the image and if you click on the Hiren boot CD's programs you get a big drop down list.
You can click on hard drive/storage to scan you hard drive. Near the bottom of the list is testing that has programs totest your PC parts. It may have the drivers for your CD drive in device drivers.
You can change the back ground if you wish.
I found https://downloads.tomsguide.com/Hiren-s-Boot-CD,0301-51033.html
and https://www.hiren.info/pages/bootcd
But I'm afraid it [PC] would crash upon diagnosis. It barely keeps on/up for 5 minutes.
I'm sure its possibe with Rufus but it would leave you doing most of the setup work to get Hiren's config. The ideal with Hiren is to take the HD, sata, and windows out of stablity issue. Try to eliminate what not causing the issue to see what part must be replaced.
