PC - Satellite P105-S6064- won't boot; Power Light flashes once but Optical Drive light flickers endlessly.
Page 4 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
145
Hello. I recently changed my HDD (over a month though) and it has been doing just fine, off course there would be this issue and that. But the focus of my post is a recent problem I encountered while surfing the net and browsing some files: the Optical Drive gave a sound and upon checking, only 'C:/', 'DVD RW DRIVE (D:/)' were present and 'CD Drive (E:/)' was missing (all of this, though there wasn't a disc inside the drive was baffling); PC suddenly turned blue with some white-black horizontal lines moving up, just like on an unset TV; it continued until I force-shutdown the thing and after some seconds when I tried to power it on, the power light flashed once and was off again but the optical drive kept flickering as it does when a DVD/CD is inserted.
I checked the HDD and RAM to see if it they were hot, but warmth degree was negligible-the RAM was even less- then next I checked the screen cable but found it connected. After fixing everything back and pressing the power key, the PC was on again?!
Session was lost but it was working again. This morning upon pressing the power key again I was able to work on my computer until it repeated the blue-screen.... I can't remember if I forced it to shutdown, but I was able to use it after some minutes.
Note: The blue screen wasn't a BSOD as it was purplish and not purely blue, and darker too.
-The missing 'CD Drive E:/' occasionally presented itself when I checked 'Computer' and Optical Drive light would flicker, but this is the time everything would stop.
-After turning on the PC, 'Opera' browser as I was using it, would 'glow' the desktop wallpaper as if it was set in transparency mode for short milliseconds and after about 5secs. would be back to normal.
-I have recently installed Puppy Linux (Slacko 6.3._) as a backup OS after checking it using a Live USB, so I could retrieve my files in case anything goes wrong with Windows. It might not be the problem, but I think its worth noting. And there's also a free 1022 or 1024 MB if free partition left after installing Puppy.
-I use Plop boot manager.
-RAM= 2GB.
-HDD= 500GB.
-Its a Windows 7, x32 bit PC.
HOPE THE DETAILS WOULD BE INFORMATIVE ENOUGH TO TROUBLESHOOT THE COMPUTER.
Only way to know for sure is swap out parts. Most shops have battery, HD, CD drive, spare power cord, memory, monitor to test. If none of those fix the problem then they know its the motherboard needing replacement.
That's why I kept a standalone drive for it.
So 'bout the PC what's the real problem behind everything all this long?
I had an idea to recheck things up, so I can report: but everytime I press the power button, the power light just blinks once and nothing again; I continued once in a while until ut booted into Windows, and I had the liberty of copying a link to download a '.Net Framework'; it went off by utself and I couldn't get it in again. I tried my live USB and it didn't work, and so I removed the HDD; results were same without the HDD too; I cannot boot without it, even using the Live USB.
If its happening even with the USB you probably have hardware failer. I would guess the motherboard has solder issues with parts getting lose. The solder could also be getting bad causing issues with eletrical pass though. You could try taking the motherboard out and look it over for melted or burnt parts. Also check the solder to see if its bad.
Could be some of the parts on the motherboard like bulging capacitor or SMD.
I do not think its anything if the sort, though I'm not sure about the CPU (top on the image) and heatsink (bottom);
I also broke part of some tiny metal piece while fixing back the Motherboard: 'PAD 5'. Hope its not a problem;
That covers a huge amount of problems. Its call many things such as heating, aging, cracking, bullseyeing, and ect. Those are used to state if the solder has voids in the solder joints, excessive temperature/thermal stress in the soldering process, insufficient solder, and other defects that may cause them no longer make a connection. This happens on video cards and people try to heat them to reflow the solder. Some times that works other times it doesn't. Your motherboard tho has parts that can be damaged by heat so that wouldn't work. I would suggest the replacement motherboard.
Only way to be sure it swap out for know working parts. With both drivers showing up bad which is unlikely has to be up the chain. IE drive cable or what the drive cable connects to which is the motherboard. The USB doing the same means everything is pointing at the motherboard or something on the motherboard.
Switch board connector & Touchpad + connector too.
Switch board, please; one with the power button &c, located just above the keyboard.
Further info at: http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
I should've posted sooner, "but better late than never":
This is the scan of 160GB (SAMSUNG) HDD
Next, are images for 500GB (Western Digital) HDD scans, the last two being results of the process;
Sorry I could not get clearer images; but with the cursor/touchpad's connector damaged, I can't take proper screenshots; cursor does not even appear on Hiren's, maybe 'cause its undetected.
