PC - Satellite P105-S6064- won't boot; Power Light flashes once but Optical Drive light flickers endlessly.
Page 5 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
145
Hello. I recently changed my HDD (over a month though) and it has been doing just fine, off course there would be this issue and that. But the focus of my post is a recent problem I encountered while surfing the net and browsing some files: the Optical Drive gave a sound and upon checking, only 'C:/', 'DVD RW DRIVE (D:/)' were present and 'CD Drive (E:/)' was missing (all of this, though there wasn't a disc inside the drive was baffling); PC suddenly turned blue with some white-black horizontal lines moving up, just like on an unset TV; it continued until I force-shutdown the thing and after some seconds when I tried to power it on, the power light flashed once and was off again but the optical drive kept flickering as it does when a DVD/CD is inserted.
I checked the HDD and RAM to see if it they were hot, but warmth degree was negligible-the RAM was even less- then next I checked the screen cable but found it connected. After fixing everything back and pressing the power key, the PC was on again?!
Session was lost but it was working again. This morning upon pressing the power key again I was able to work on my computer until it repeated the blue-screen.... I can't remember if I forced it to shutdown, but I was able to use it after some minutes.
Note: The blue screen wasn't a BSOD as it was purplish and not purely blue, and darker too.
-The missing 'CD Drive E:/' occasionally presented itself when I checked 'Computer' and Optical Drive light would flicker, but this is the time everything would stop.
-After turning on the PC, 'Opera' browser as I was using it, would 'glow' the desktop wallpaper as if it was set in transparency mode for short milliseconds and after about 5secs. would be back to normal.
-I have recently installed Puppy Linux (Slacko 6.3._) as a backup OS after checking it using a Live USB, so I could retrieve my files in case anything goes wrong with Windows. It might not be the problem, but I think its worth noting. And there's also a free 1022 or 1024 MB if free partition left after installing Puppy.
-I use Plop boot manager.
-RAM= 2GB.
-HDD= 500GB.
-Its a Windows 7, x32 bit PC.
HOPE THE DETAILS WOULD BE INFORMATIVE ENOUGH TO TROUBLESHOOT THE COMPUTER.
Only way to know for sure is swap out parts. Most shops have battery, HD, CD drive, spare power cord, memory, monitor to test. If none of those fix the problem then they know its the motherboard needing replacement.
The touch pad should have the connector ribbon on the back. Your current ribbon cable should also be good.
Yes, that's exactly the cable I'm referring to: the touchpad has over three connectors and four cables; two connectors from left & right click buttons and the third from touch panel; each has a cable + a fourth which gets to the Motherboard.
Its the part detached from mothetboard at exactly 6mins:10-13 seconds on the video above, then the fingerprint cable, just before removing top cover assembly.
Didn't see message earlier, sorry.
