Question PC showing red cpu led and fans speed up after a bit
umairyousif239
20
Hi,
I was using my pc and it froze, so i restarted it but after restarting the pc didnt turn on, it showed red light on cpu led and the fan sped up.
We're going to need more info.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. List them like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
How old is your PSU? What was the last thing you were doing on your PC before the issue cropped up?
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Its an office pc, so i'll drop as much info as i can
CPU: Core 2 Duo E8500
Motherboard: some intel one
Ram: 4GB
SSD/HDD: 500GB
PSU: also a pre included one
OS: windows 10
I was playing a game and it just froze up
https://forums.tomshardware.com/thr...d-and-fans-speed-up-after-a-bit.3482066/reply
Can the CPU-Z app tell us the exact motherboard? We might be able to find the manual online.
I’m guessing the red light indicates either overheating or a power failure to the CPU, at any rate.
If it now won't even POST, probably liittle worry about overheating, but, for sure thermal paste on a heatsink does not last forever. You can try a new BIOS battery for $3, perhaps slave in a known good PSU to rule that out, test with one stick of RAM alternately, eventually leaving you only with the mainboard (once you remove/disconnect everything else ruling out other potential causes. (a mainboard failure is 10-20x more likely than an actual 'out of the blue' true hard cpu failure...
Ok so i removed one ram stick and it started working, guess that stick causing all the trouble
