Question PC wont post after swaping CPUs
Feb 1, 2024
Halo, I got quite the problem with my pc, I’ve been wanting to upgrade my cpu for some time and I asked buddy to borrow his cpu to test on my pc. Everything was great untill I had to put my cpu back, let’s say I couldn’t get it to fit in socket from the first few tries and ended up forcing it a bit, when I tried to power on the pc it didn’t post. The pc doesn't turn off it just stays with no signal and everything spins/lights up inside the pc, I tought I damaged a pin on the cpu and ended up trying my buddy cpu again only to find it didnt work either (it worked when he put it back on his pc).The igpu doesnt work either and my gpu works just fine on another pc.
So, since the cpu and gpu don’t seem to be the problem could have I damaged a something on the cpu socket on the mobo that would cause this?
The mobo is hvs 510, socket 1200.
This is a photo of how the socket looks like View: https://imgur.com/9DJpZAn
Another thing I noticed is that the usb ports do not charge (like charge the phone) unless the pc is turned on.
What's your system specs? also include your new CPU as well.
It could be because it needs a BIOS update for the newer version CPU to work.
I didnt brought the new cpu yet. My specs are i3 10100f, rx 6600. The cpu I tested was i5 10600kf. I have one stick of single channel ram 16gb, the movo is h510M-HVS V2, the socket 1200
