Hello
My PC started having issues since a couple days ago.
Usually, I click the power button, the case LED turns on, fans start spinning full speed and they slow down after the bios screen appears. Now, when I click the button the fans start spinning full speed and never slow down so my monitor never receives a signal and the case LED sometimes is very dim or doesn't turn on at all. It's the same unless I try it numerous times that the PC finally turns on with no problems.
Pc Specs:
Asus P7H55-M LX - MOBO
Cooler Master B700 - PSU
Intel Core i7-870 - CPU
Corsair H75 - CPU COOLER
2X4GB 1333 DDR3 - RAM
Asus GTX 760 4GB - GPU
I recently upgraded my PSU,GPU,RAM and CPU cooler and they work flawlessly when the PC is on, so they're definitely not the issue.
Could this be a motherboard problem? I really hope not because than i would have to upgrade to a new Motherboard and i can't afford to get a new CPU right now.
Any help would be greatly appreciated!
Also i'm not sure what category this belongs to so i set it to Components,
Pc Specs:
