[SOLVED] PC won't work after botched GPU overclock.
Feb 12, 2020
I have built a new PC but after applying an in correct core clock to my GPU in Afterburner my will not let me log into it because of the overclock.
I can go into a separate user profile in Windows but I cannot go into my profile because the boost is set to "startup"
I have tried disabling GPU to just use onboard graphics and then disable Afterburner but PC won't let me. I've been at it for hours.
Specs: Ryzen 7 3800x Rtx 2080 Super 16gb ripjaws ddr4 2166? Unknown PSU
I've fixed it. I think. I went into networked safe mode and after searching through the program files I found that I had multiple Afterburners installations in different drives.
I uninstalled all of them and then restarted my system. As far as I can see, I can now use my regular profile.
Thanks for the help!
