PCIe or External Sound Card??
tomtomhoch
54
Hi,
I want to get a sound card for my computer so that I can take advantage of my 5.1 surround sound speakers but my motherboard only has one PCI card slot (I think that's what the big one is called!) which is taken up by my graphics card, however I do have one spare PCIe slot (The other taken up with a wireless card) I'm not sure whether to get a PCIe Sound Card which is quite expensive compared to a PCI one or to get an external one. My budget is £20 - £30.
Can you recommend any particular cards and whether internal PCIe or external is better??
This is the motherboard I have - MSI H61m-P23
Thanks
Thomas
The DGX is just as good when it comes to music/movies. Heck, the C-Media chipset its built on has ALWAYS been geared toward music and movies, mostly because Creative has been so focused on gaming...
Have you tried using the onboard sound? The VIA chip you have is suppose to provide for 5.1
You motherboard's slots that are available are PCIex1. That is the type of interface the card requires if you go with an internal one. I prefer internal, but that's me. Here are some 5.1 internal cards available: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100009293%20600011982%20600011890&IsNodeId=1&name=5.1&ShowDeactivatedMark=False
I have this one, but I don't think it's available anymore except maybe used like on ebay: http://support.creative.com/Products/ProductDetails.aspx?catID=1&CatName=Sound%20Blaster&subCatID=208&subCatName=X-Fi&prodID=17927&prodName=Sound%20Blaster%20X-Fi%20Titanium&bTopTwenty=1&VARSET=prodfaq😛RODFAQ_17927,VARSET=CategoryID:1
I have tried the VIA audio but it's rubbish and the 5.1 doesn't work. I read on the internet that nearly everyone has the same problem! I have decided that I will probably just get a new motherboard and case and rebuild my computer so that i have a spare PCI slot! Thanks for your help!
Thanks
Thomas
