Hello !
So, some time ago my old GPU (PNY GTX 770 4GB) died while I was playing valorant and it took me a while to get a new one.
In the mean time a friend of mine gave me his old gpu so I could test it out it was a 9800GT, I installed it in the pciex16 slot and it worked just fine, the pc recognized it, so i just assumed that it really was my old one that died.
The thing is, now I got a GTX 1660 ti OC edition, and tried using it in the pciex16 slot but it simply wouldn't work, the fans would turn on just fine but I got no image from either hdmi or dp ports, and wouldn't show up in windows device manager aswell. Since my MB has a PcieX4 port I tried installing it there and it worked just fine, I read online that for this GPU it wouldn't impact performance as much, but it got me thinking what was the problem since the old 9800gt was working just fine on that PCIex16.
Any Ideas ? Is the problem in the pciex16 slot or is it the 1660 ti ?
PC SPECS
MB: Gigabyte z87-hd3 (BIOS PC4)
CPU: i5 4670k
RAM: 2x8gb 1333mhz
GPU: Gigabyte gtx 1660ti oc
PSU: Corsair CX 750W
OS: Windows 10 Pro 64 bits
Note: Everything with the exception of the 1660 ti was bought a long time ago (2014).
And sorry if a similar problem was already posted, I couldn't find it
PC SPECS
CPU: i5 4670k
RAM: 2x8gb 1333mhz
