Eric513
80
Hey all, just built and set up my new computer yesterday, and I've started some overclocking. (This is my first home built computer so I'm not savvy with overclocking quite yet.) So far, I've put the multiplier to x17 and that puts the clock speed to 3.4GHz, but it randomly drops to x4 and 800MHz. Anyone mind helping me fix this and hopefully overclock some more?
Also if it helps, from what I've seen on BIOS, the system temp is 15C and the CPU temp is 23C-24C
Thanks!
EDIT- If you guys need any other system/hardware info, just ask and I'll put them up. Just was too lazy to put everything up there if it wasn't needed. :D
UPDATE - I'm up to 3.6GHz with x18 multiplier and 1.3625V, running prime95, the core temp is staying at about 50C, any suggestions?
keefygeorge
25
Ok mate you need to go into your BIOS settings and change the cpu multiplier from auto to your desired speed.
when the multiplier is set to auto it downclocks automaticly at idle to save power.
It can be easily turned off.
Eric513
80
Alright, thanks! I've got pretty good air cooling, so how high do you think I can safely get the multiplier/voltage?
keefygeorge
25
The best way i find is to use amd o/d for testing so theres no need for a cemos reset.
But turn off auto multiplier from bios first or you will crash..
Im running 1.3625v with 18 multiplier.
dont try this setting yet though.
It really depends on your mobo and cooler.
Eric513
80
Well heres my cooling:
Antec 900 (2 front 120mm fans, 1 back 120mm fan, 1 top 200mm fan, also installed a side 120mm fan)
Arctic silver 5 on CPU
Xigmatek Dark Knight on CPU
keefygeorge
25
Ok well i checked you board and you have some good headroom for o/cing.
Try amd overdrive it saves a lot of rebooting and fiddling.
Once you find your happy point then use the bios.
keefygeorge
25
This is what someone has achieved on that board so far. So you should be right to bump it up but do it bit by bit. Increase the multiplier to 17 and run a stability test for at least an hour. If your temps are good increase the voltage and keep trying.
keefygeorge
25
My Specs and settings.
Antec900, M700 750w, Phenom II x4 940 with CNPS9500 cooler, MA_790FX-UD5P,
ATI HD4870x2, Kingston ddr2800,
I have my multiplier set to x18. with 1.3625 @3600Mhz
keefygeorge
25
Hey mate sorry i was away.
You a lot better off using amd overdrive its designed for amd processors.
Its also very user friendly.
PM me your email ill link you some specs.
Eric513
80
Alright I bumped it up to x18 (3.6) with 1.3625V and the core temp is balancing out at about 50C, would that qualify as stable?
keefygeorge
25
Make sure you register with prime95 and connect to the prime net server.
This way you can run auto tests and the server will make sure your running the right tests. :)
