PHost, PBP-queue und build order
G
Guest
Guest
Archived from groups: alt.games.vga-planets (More info?)
Hello,
assume the following setup: phost with pbp-queue enabled.
If there is not PBP-build being carried out the docs say, that any slots
still open will be filled using the FIFO-queue, so oldest build order
processed first.
My question now: what is the build order for builds that have been
ordered at the same time (at the same turn)?
per-planetID-order?
per-player-order?
Best regards,
Ingo
Ingo von Borstel <newsgroups@planetmaker.de>
Public Key: http://www.planetmaker.de/ingo.asc
If you need an urgent reply, replace newsgroups by vgap.
> My question now: what is the build order for builds that have been ordered at
Planet Id order starting with a random planet
